Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! #1808497
04/21/15 11:20 AM
04/21/15 11:20 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
With ease...
Re: Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! [Re: Defbob] #1808665
04/21/15 03:25 PM
04/21/15 03:25 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Sitting level. Looks like it was made to do just that.
It would be really neat if those axles and tires were under it, instead of on it.
I have mechanical Aptitude.
I can screw up anything.
Re: Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! [Re: bboogieart] #1808711
04/21/15 04:30 PM
04/21/15 04:30 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
The crates weigh 1980lbs each and the tires are 225lbs each. Thats 4,860lbs in the bed. The truck weighs 8900lbs empty with the CM bed on it.
Re: Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! [Re: Defbob] #1808714
04/21/15 04:31 PM
04/21/15 04:31 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
15.5/80R20 Michelin Pilote G20 XL tires. 46.5" tall x 15.5" wide
Re: Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! [Re: Defbob] #1808746
04/21/15 05:24 PM
04/21/15 05:24 PM
New Brunswick, Canada
TrxR Offline
TrxR  Offline
What are you using them for?
Re: Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! [Re: Defbob] #1809251
04/22/15 10:04 AM
04/22/15 10:04 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Not sure yet. Dodge D600 maybe
Re: Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! [Re: Defbob] #1809253
04/22/15 10:06 AM
04/22/15 10:06 AM
scratchnfotraction Offline
what gears are in that size axle?
Re: Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! [Re: Defbob] #1809432
04/22/15 02:24 PM
04/22/15 02:24 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Did a Google search on those axles and guys are putting them on everything, Envoys and Trailblazers seem popular! I know off roading parts need to be tough but thats ridiculous. Be cool on a very capable D600 though......
Also something you have to watch out for is the paint on those axles is very toxic (I'm sure you already know this). It's some sort of special paint for withstanding chemical agents?
Re: Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! [Re: Defbob] #1809450
04/22/15 02:54 PM
04/22/15 02:54 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
my axles are 5.64 ratio overall. 1.58 ring pinion, 3.55 planetaries
Re: Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! [Re: Defbob] #1809451
04/22/15 02:54 PM
04/22/15 02:54 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
My T600 t-case has 2.45 low gear.
Re: Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! [Re: Defbob] #1809606
04/22/15 05:51 PM
04/22/15 05:51 PM
a stock 4-v 318 should be plenty of power for those gears. laugh2
Re: Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! [Re: TrxR] #1810551
04/23/15 10:52 PM
04/23/15 10:52 PM
ky.
K
kenworth_goose Offline
K
ky.
Why would that be such a surprise? I've had 205 8x8x16 concrete block in the bed of my 99 3/4 ton 5.9 gas truck and it haul it with ease! [img:center]http://[/img]
Re: Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! [Re: Defbob] #1812969
04/27/15 12:49 PM
04/27/15 12:49 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Put those wheels and tires under the Willys....
Re: Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! [Re: Sixpak] #1818810
05/04/15 08:46 PM
05/04/15 08:46 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
And it can handle the matching transfer case too...
Re: Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! [Re: Defbob] #1818812
05/04/15 08:47 PM
05/04/15 08:47 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
dino
Re: Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! [Re: Defbob] #1819273
05/05/15 12:18 PM
05/05/15 12:18 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
that makes the np205 look like a child's toy
Re: Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! [Re: CTD5.9] #1828048
05/16/15 09:21 PM
05/16/15 09:21 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
2001 Caterpillar 3126B with Eaton Fuller 5spd. drive
Re: Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! [Re: Defbob] #1830636
05/20/15 10:07 AM
05/20/15 10:07 AM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Cool wear did you get all that stuff? I have worked on and rebuilt those axles,transfer case when I worked on MRAPS for the US.ARMY. they were used in RG31 MK3 and MK5. What are you building? Sounds cool whatever it is.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! [Re: mopar65] #1831102
05/20/15 09:53 PM
05/20/15 09:53 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Not sure yet. Still have to find a body. Maybe a 50's Mack A50 or something.
Re: Yes, a Ram 3500 6.7L can haul a pair of Axletech 4000 axles! [Re: Defbob] #1831226
05/21/15 12:20 AM
05/21/15 12:20 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Whichever vehicle you decide on, its going to be a freakin' unstoppable monster!!
Gone to the dark side with an LS3 powered '57 Chevy 210
