Re: Need some direction for modding my 5.9
[Re: 67MIke]
#1810496
04/23/15 09:57 PM
04/23/15 09:57 PM
Posts: 3,150 Central NC
gch
Central NC
If you have any interest in an M1 intake and a larger throttle body let me know.I have acquired stuff for my 5.2 Grand Cherokee and have since sold the Jeep.I will be listing parts soon.
[Re: 67MIke]
#1810499
04/23/15 10:00 PM
04/23/15 10:00 PM
gch
Central NC
First thing to do is air in/out.I would start with the K&N cold air intake and then improve the exhaust.A high flow cat and 3" single exhaust will wake it up.Headers a little more. Then you can look at intake/1.7 roller rockers/cams/Throttle bodies,etc.
Edit;A good basic tuneup of plugs/wires/cap/rotor/fuel filter(if external)is a good place to start before hopping it up.
[Re: gch]
#1811278
04/25/15 12:05 AM
04/25/15 12:05 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
What's your budget? An M1, some decent mid-length headers, and a cam, along with SCT to reprogram the PCM (total investment ~$1200 total, will net you an easy 100hp.
Those mods on my 318 Dakota had it running mid 14 sec 1/4 miles (with 2.3 sec 60' times due to slippery street tires...with traction, low 14s were possible.
Those same mods with a 5.9 has my truck now running low 14s, and still traction limited.
**Photobucket sucks**
[Re: 70Cuda383]
#1811282
04/25/15 12:09 AM
04/25/15 12:09 AM
70Cuda383
Marysville, O-H-I-O
A 2bbl m1, and a stock-ish cam will still tow fine too. Essentially you lose no bottom end and pick up substantial power from 4500-6000 rpm.
If budget is a concern, start with just SCT. For about $400, you get unlimited tuning. This allows you to make a considerable gain on otherwise stock hardware, while allowing to retune as you make other mods.
