Re: drums to disc,what master cylinder???
[Re: hp340nos]
#1810180
04/23/15 02:46 PM
04/23/15 02:46 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
When I converted my '64 Polara to Disc/Drum brakes I followed the Mopar Action parts list for everything but the master. I called Stainless Steel brake in SC and got a manual brake twin reservoir unit with a proportioning valve attached for reasonable money. You need more line pressure for the disc side to make it work and less for the drum side to prevent lockup.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Pentastar440]
#1810193
04/23/15 03:02 PM
04/23/15 03:02 PM
Posts: 4,672 Wichita
GY3
Wichita
Very nice setup.. The larger bore has a firm pedal. Might be too firm for some..
[Re: hp340nos]
#1810302
04/23/15 05:57 PM
04/23/15 05:57 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
When I changed my 67 Barracuda over I think I used 78 Dodge 1/2 ton pick up master cylinder
