need some help with some tires wheels & mini tub? #1809791
04/22/15 10:59 PM
04/22/15 10:59 PM
yellow70charger Offline OP
Hi guys I have a 70 charger I'm looking on doing a mini tubs. I've seen some posts on how you guys did yours but two questions, like did you take the inner wheel well all the way flush with the frame or did you leave the lip of the frame rail? what size rims are you guys running 10 inch 12 inch? and with what tire on a 10 inch or 12 inch and did you trim or roll the outer wheel opening.
any replies will be greatly appreciated as I planned to do this project in the next few weeks
Re: need some help with some tires wheels & mini tub? [Re: yellow70charger] #1809836
04/22/15 11:51 PM
04/22/15 11:51 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
A 10" wheel fits a stock tub so 12's would be in order with mini tubs. The general concensus seems to be to take them right to the rail.
Re: need some help with some tires wheels & mini tub? [Re: yellow70charger] #1809975
04/23/15 07:54 AM
04/23/15 07:54 AM
pa
572charger Offline
572charger  Offline
pa
my 68 charger is right to the rail with a stock width dana 60 i have a 31 x 16.50 tire under it witha 7 1/4 back space wheel and had to trim the ft edge of the quarter panel opening !!!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: need some help with some tires wheels & mini tub? [Re: 572charger] #1810060
04/23/15 12:10 PM
04/23/15 12:10 PM
mn.
taxidermy man Offline
mn.
572, what width wheel are you using? Also what kind of front wheel do you have? I thought I saw a pic. of your car some where and I didn't recognize the wheel. Always liked your car.
Re: need some help with some tires wheels & mini tub? [Re: yellow70charger] #1810749
04/24/15 07:48 AM
04/24/15 07:48 AM
pa
572charger Offline
572charger  Offline
pa
right now i have a 12 " wide trackstar wheel on the rear i cut the moser dana 60 down 1 1/2 inch on each side i think if i remember right it has a 5 " back space now !! years ago u could buy the cenerline autodrag with a 7 1/4 back space with 12" wide wheel on a stock houseing width !!!! my frt wheels are a nother story i BROKE 3 sets of ft wheels ? put my old alumistars back on the frt i BROKE the frt track stars , i BROKE the 1 piece billet trackstars and i BROKE a set of the rt-s wheels weld told me i can't break !!!!!!!
Re: need some help with some tires wheels & mini tub? [Re: 572charger] #1810822
04/24/15 11:45 AM
04/24/15 11:45 AM
mn.
mn.
Thanks Jim, breaking front wheels like that seams odd, even if your a car wheel stands big time.
