What choices for drop spindles on a '72 Satellite? #1807918
04/20/15 05:43 PM
04/20/15 05:43 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Geesh! $440.00 for a set of drop spindles from Magnum Force is too much dough for my budget. Anyone know of a better deal from another vendor?
I also understand that C-body spindles are an option. Has anyone done that swap or know about the details of what else needs to be done, and what can be gained by using the C-body method?
Thanks for hopefully making my day!
Re: What choices for drop spindles on a '72 Satellite? [Re: Hooligan] #1807939
04/20/15 05:56 PM
04/20/15 05:56 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Don't buy the Fatman spindles that are flat steel with welded ends. Low quality, interference issues, etc. I don't think they sell them anymore anyways. But you never know.
Re: What choices for drop spindles on a '72 Satellite? [Re: autoxcuda] #1807946
04/20/15 06:05 PM
04/20/15 06:05 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Note to self... Drop Fatman from the list.
Re: What choices for drop spindles on a '72 Satellite? [Re: Hooligan] #1808810
04/21/15 06:43 PM
04/21/15 06:43 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
PST for $499
You might someone reselling a set form one of these two vendors, but you probably aren't going to find any screaming deals.
Some C body units are an inch drop, but are not a direct bolt in either because of differing ball joint tapers and bolt patterns.
Re: What choices for drop spindles on a '72 Satellite? [Re: Hooligan] #1808847
04/21/15 07:45 PM
04/21/15 07:45 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Don't buy the cheapest spindles you can find. Your continued existence in this life will thank you.
Re: What choices for drop spindles on a '72 Satellite? [Re: Lefty] #1809077
04/21/15 11:32 PM
04/21/15 11:32 PM
IN
ahy Offline
ahy  Offline
IN
Don't know how much you want to drop... but stock spindles, crank down the T bar adjuster somewhat and stiffer T bars can provide a meaningful amount of drop without bad side effects.
Re: What choices for drop spindles on a '72 Satellite? [Re: ahy] #1809154
04/22/15 01:26 AM
04/22/15 01:26 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I'm not sure what material the Magnum Force spindle/knuckles are made from, but beware: A buddy of mine has them on his 71 Challenger and wheel bearing failures caused excessive wear to the spindle portion. He said a groove formed approx 1/3 of the way through the spindle.
I agree that stiffer T bars plus a modest 1 inch to 1.25 drop is a far better idea.
Re: What choices for drop spindles on a '72 Satellite? [Re: Hooligan] #1809255
04/22/15 10:14 AM
04/22/15 10:14 AM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
I have the Magnum Force spindles on my 69 Barracuda. 5 years 2 long haul Hot Rod Power Tours later, it's the only way I would lower one. Full suspension travel is the best way.
NMCA NSS 67 Coronet
Re: What choices for drop spindles on a '72 Satellite? [Re: Hooligan] #1809321
04/22/15 12:07 PM
04/22/15 12:07 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
I was away for a few days, but I decided to back off the torsion bar bolts to the max, and the car dropped a good 2 inches! I didn't try it before... thinking not much would happen, but now the control arms and tie rods are level with the ground. The K-member is 6 inches from the ground, and the rubber LCA bumpers are a half inch from the frame. The engine is a 360 6-bbl. (sorry, no car pics yet)
Now I plan to bring the rear of the car down with a home-brewed 4-link set up, and I suppose it would be a good idea to also install tubular upper A-arms to correct the camber and caster issues.
It sure is strange looking down at the car now. I feel like a giant!
Thanks everyone!
Re: What choices for drop spindles on a '72 Satellite? [Re: Hooligan] #1809398
04/22/15 01:26 PM
04/22/15 01:26 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thanks everyone!
The camber caster "issue" can be adjusted by getting a new proper alignment. When you change the ride height down or even up like that the alignment changes. When a drag guy raises the front end for weight transfer, header clearance, oil pan clearance, etc, etc he has to get a new alignment too.
Tubular upper A-arm have the same geometry as stock one (except for Hotchkis E/B-body). And even then the Hotchkis geometry change is for bumpsteer not ride height. Tubular A-arms are not necessary for lowering you car like that.
You can change you lower control arm bumper to shorter ones that Energy Suspension sells: http://www.jegs.com/i/Energy-Suspension/355/9-9102G/10002/-1 Still I would not go too low with stock T-bars. .99" or 1" If you K- member is 6" from ground, you don't sound that low. Need more info though.
What is the diameter of your front tires?
That number with K-member height gives an idea where the suspension geometry is.
Re: What choices for drop spindles on a '72 Satellite? [Re: Hooligan] #1809603
04/22/15 05:47 PM
04/22/15 05:47 PM
AndyF Online content
AndyF  Online Content
We never found any dropped knuckles that we trusted for Tim's red Valiant so we just ran the stock suspension dropped as low as it would go.
If there was a high quality dropped knuckle on the market I would use it. Even better would be a dropped knuckle that was designed to use a sealed hub like the newer Mustangs have.
Re: What choices for drop spindles on a '72 Satellite? [Re: autoxcuda] #1809724
04/22/15 09:42 PM
04/22/15 09:42 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Tire diameter is 27'' and the T-bars measure a touch larger than 7/8''. (Factory 318 car)
I can change the tires because I just ordered a set of Coys C-5 wheels in 20"x10"
and 18"x8"
I heard that the factory LCA rubber bumper was designed to hit and then compress, which gives the LCA a little more travel room.
I saw the Hotchkis tubular upper arms... almost $800.00. (I'll pass on those) It looks like the little extra bracket that they have puts their arms on the same travel plane as the factor lower arms.
So... I don't need drop spindles, or tubular upper control arms. That saves me a lot of money. I guess I should consider a set of MOOG offset bushings, and maybe a pair of PST tie rod sleeves, and thicker T-bars. Ohhh, and front and rear sway bars!
Re: What choices for drop spindles on a '72 Satellite? [Re: AndyF] #1809730
04/22/15 09:50 PM
04/22/15 09:50 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
I was surprised how low my car dropped with the T-bar bolts adjusted out to the max.
Another reason to be a Mopar fanatic!
...and to think that I stayed up all night planning to remove everything up front, and build a custom strut style suspension. Hey! Wait a minute!
Re: What choices for drop spindles on a '72 Satellite? [Re: AndyF] #1809798
04/22/15 11:13 PM
04/22/15 11:13 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Thank you Andy for calling it a KNUCKLE.
Re: What choices for drop spindles on a '72 Satellite? [Re: autoxcuda] #1809905
04/23/15 01:37 AM
04/23/15 01:37 AM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
All of my bushings and ball joints are new. At this lowered height, the ball joints do not look like they will bind, so I adjusted the UCA's to these positions...
Forward cam: The bolt is at a point farthest from the engine.
Rear cam: The bolt is at a point nearest to the engine.
With that setting I have roughly 4 degrees of positive caster, and roughly 1 degree positive of camber according to my highly sophisticated magnetic angle finder. (Offset bushings might not be needed)
Tires are both slightly toed in.
I once set up a '70 Dart like this, and it drove great with perfect tire wear.
Re: What choices for drop spindles on a '72 Satellite? [Re: Hooligan] #1810113
04/23/15 01:24 PM
04/23/15 01:24 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
With those soft torsion bars you have now, you want to get rid of any positive camber you have and edge it over to the negative side. This will reduce the caster you are able to achieve, but negative camber will help keep the tread flatter as the body rolls.
Re: What choices for drop spindles on a '72 Satellite? [Re: Hooligan] #1810315
04/23/15 06:07 PM
04/23/15 06:07 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Fatman spindles on mine, no issues. That was before Magnum had them but the former are as expensive. Sounds like if you're not bottoming out on the bump stops (rough ride), you're good to go.
Re: What choices for drop spindles on a '72 Satellite? [Re: TC@HP2] #1810584
04/23/15 11:34 PM
04/23/15 11:34 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Sounds like it will take a lot of patience, and some bruised KNUCKLES to get it all dialed in.
On the positive side (no pun intended) The longer it takes me to build this car, the more new products will be developed as all the suspension companies try to "reinvent the wheel", so to speak. Sorry, I had to say it.
