Re: Crank scrapers - HP increases?
[Re: Moparmal]
#180970
01/01/09 09:33 PM
01/01/09 09:33 PM
Posts: 43,191 Bend,OR USA
Cab_Burge
I rememeber reading a article in a car mag. several years back(10 to ?) that said that on a small block Chevy that made around 600 hp at 7000 rpm the crank scraper added around 20 hp at 7000 rpm but wasn't worth any power or Tque below 5000 rpm on that dyno I wasn't there and didn't see it, like most magazine articles, so take that for what it is worth. I do make my own on all motors that will be raced at the drags now I shoot for between .030 and .045 clearances to the rods and crankshaft oo a steel rod motor in a cast iron block. Add another .030 clearnce on aluminum rods or a endurance motor or a street motor using a cast iron block.
[Re: dthemi]
#180976
01/02/09 03:29 PM
01/02/09 03:29 PM
Posts: 110 Concord California
Evil_Ways
Concord California
Who makes crank scrapers for small and big block Mopars.
[Re: Evil_Ways]
#180977
01/02/09 03:38 PM
01/02/09 03:38 PM
griff70440
[Re: jughed]
#180980
01/02/09 05:42 PM
01/02/09 05:42 PM
Triple Threat
Renton Washington
Screens are just designed to limit and slow the back splashing of oil onto the crank.
Thats how I have understood it.
[Re: dthemi]
#180981
01/02/09 06:24 PM
01/02/09 06:24 PM
Posts: 1,981 SE Michigan
TS3303
SE Michigan
I can't say exactly how much, but can assure you it will be worth power. The farther you can keep the crank away from the oil, and the more you can get off the crank the more power you'll make. Ideally like a dry sump there would be no oil in the pan, just a big decompression area in as much vacuum as could be produced.
Darren have you seen similar gains with a dry sump and scraper?
[Re: dthemi]
#180983
01/02/09 07:42 PM
01/02/09 07:42 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Scrapers help in dry sumps just like a wet sump. The oil tries to wrap up all over the crank even in a dry sump. the more you can scrape off the better. I like big dry sump pans with scrapers and screens, and a big bulge on the side for the oil to get slung into.
Windage trays,baffeling,and simple direction oil catches will gain you 10 to 20 Hp.Elaborate closefitting scrapers,wide block(oil pan rails),wide pans,drain down control with proper crankcase ventalation will net you much more.Determining how much depends on the oil control factored by the amount of oil passing from the clearences that splash lube the rotating parts as well as the cylinder walls.Scraper minimize the splash oil and most componants can live on suspended mist lubercation.I wouldn't recommend it for long duration running,but it would be excellent for short duration race engines.
[Re: Locomotion]
#180986
01/03/09 07:05 PM
01/03/09 07:05 PM
Posts: 411 Portersville, Pa
1badx
Portersville, Pa
I never felt comfortable with windage trays, especially with a deeper sump that keeps the oil level further away from the rotating assembly.
I am running my first deep sump/aluminum rod/stock stroke engine and saw this thread and have to ask what are your thoughts on running a windage tray. I have always run one with a stock pan. Should I run a windage tray with the Milodon 10qt pan and aluminum rods?
