Mercedes fan fix? #1809417
04/22/15 02:08 PM
04/22/15 02:08 PM
Itasca, Texas
Mad_Scientist Offline OP
Itasca, Texas
Hi,
I've been wiring and setting up my new Mercedes fan for the summer, but I'm having an issue. I purchased the control box and wired everything up like the instructions said and nothing happened when it got up to temp. I tried to test the fan like a previous post stated, but it wouldn't come on. I've had the fan for several years and it was pulled off a car in the junkyard. Is there anything that I can do to fix the fan or am I going to have to buy a new fan?
Thanks,
Tim
69 Super Bee 440 5-speed
70 Dart Swinger 340 4-speed
69 Camaro SS 396 4-speed
66 Cutlass Convertilbe
70 Judge Ram Air III 4-speed
68 F-100 SWB
Re: Mercedes fan fix? [Re: Mad_Scientist] #1809435
04/22/15 02:32 PM
04/22/15 02:32 PM
Andrewh Offline
Andrewh  Offline
I think someone verified a 12 volt charger on the 2 amp setting won't burn out the ones that need the control box.
have you tried wiring that up directly and using the small wire to start it?
also tried to spin it by hand to see if it is just stuck?
Re: Mercedes fan fix? [Re: Mad_Scientist] #1809459
04/22/15 03:00 PM
04/22/15 03:00 PM
Itasca, Texas
Itasca, Texas
I tried to "hot wire" the fan by jumping one of the small wires to the main wire that ran to the battery post and grounding the other main wire, but no luck. I get a small spark that jumps when I hook up the main wire but the fan doesn't make a noise at all. It never smoked either. I'm pretty sure it is the fan. Mine is the one that doesn't have to have the control box. The fan spins free and I don't see anything wrong with it externally. Looks brand new really. I guess it would have to be that internal module made into the shroud the or the motor. Any ideas on how to test that, and are those replaceable? Cost effective to just buy a new one of Flea-bay?
68 F-100 SWB
Re: Mercedes fan fix? [Re: Mad_Scientist] #1809552
04/22/15 04:34 PM
04/22/15 04:34 PM
Andrewh Offline
Andrewh  Offline
did you try both small wires?
neither is a ground. don't ground one, just try them both to power, one at a time.
if it won't spin up with that by itself, then yeah, you need another fan.
Re: Mercedes fan fix? [Re: Andrewh] #1809623
04/22/15 06:20 PM
04/22/15 06:20 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I remember testing mine out and it not working. Before buying another leave it hooked up longer. There is a 5 to 10 sec. delay before it will start even when hotwiring it.
Re: Mercedes fan fix? [Re: Mad_Scientist] #1809630
04/22/15 06:42 PM
04/22/15 06:42 PM
hooziewhatsit Offline
Touch the trigger wire to power, and after 3-5 seconds the fan should kick on.
Re: Mercedes fan fix? [Re: Mad_Scientist] #1810071
04/23/15 12:23 PM
04/23/15 12:23 PM
Itasca, Texas
Itasca, Texas
I'll do a little more testing this weekend just to be sure.
I remember that when I first bought my fan, the controller box wasn't out yet. Now that we have that, I think I can run the reproduction fan. What year fan would you recommend when running the controller box?
68 F-100 SWB
Re: Mercedes fan fix? [Re: Mad_Scientist] #1811277
04/25/15 12:05 AM
04/25/15 12:05 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
I have an extra one of those fans.Just sayin.
