Re: Hemi ProStock heads on a Merlin pro cgi block?
[Re: coletrickle]
#1810070
04/23/15 12:23 PM
04/23/15 12:23 PM
Posts: 1,839 NW Indiana
fbs63
NW Indiana
I had talked to C&C Motorsports about on of their aluminum Ford A460 blocks. They are 4.900 bore space and they said if you send them a head gasket they would drill it for the PS Hemi bolt pattern. They make the blocks in a variety of deck heights. c&cmotorsports.com
[Re: coletrickle]
#1813474
04/27/15 10:57 PM
04/27/15 10:57 PM
Posts: 6,139 Melbourne , Australia
LA360
Hemi 99 stuff and cheap won't ever be in the same sentence. If you were doing your planned machine work yourself, it would probably be a viable exercise. Depending on what the geometry of the lifter bores end up being, you will most likely require a custom cam core (The lobe phasing will most likely be different)
Alan Jones
