SB oil filter adapter gasket # #1809225
04/22/15 08:13 AM
04/22/15 08:13 AM
Sharpsburg Maryland
440farmer Offline OP
Sharpsburg Maryland
Can anyone help me with a felpro or chry # for the gaskets for the right angle factory oil filter adapter/right angle piece?
Re: SB oil filter adapter gasket # [Re: 440farmer] #1809242
04/22/15 09:34 AM
04/22/15 09:34 AM
The Felpro # is 70078 but that is only the round circular gasket for the flat filter adapter (underneath it). You'd need the MP 3 piece gasket set for the 90 deg adapter. the felpro circular gasket is a bit thicker than the MP one (preferred) & for the 90 deg adapter/3 ;iece gasket set needed you could fab a thin gasket to go under the bolt head on the outside but you'd still need the thick cork gasket to go on the bolt on the inside. Make sure the block recess is squeaky clean & know the correct clocking so when you lift the 90 deg adapter up into place you go straight up into place & do not move it once it is up there & have the ring gasket SECURELY cemented in place in the block recess first. 50 lbs on the bolt.
Re: SB oil filter adapter gasket # [Re: 440farmer] #1809247
04/22/15 09:51 AM
04/22/15 09:51 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Superformance offers a very nice kit for that.
http://www.superformanceproducts.com/catalog/2013CatalogRacerNet.pdf
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: SB oil filter adapter gasket # [Re: 440farmer] #1809249
04/22/15 10:00 AM
04/22/15 10:00 AM
Sharpsburg Maryland
Sharpsburg Maryland
Thanks been through this many times just ran out of my supply of gaskets
And the part # I had seems to be no good P5249320?
I'll get the ones from superformance their great to work with.
Re: SB oil filter adapter gasket # [Re: 440farmer] #1809252
04/22/15 10:04 AM
04/22/15 10:04 AM
PA.
"Little"John
"Little"John
PA.
They do offer some very nice gaskets and they are a Moparts supporter too. I made the switch to his gaskets and couldn't be happier. Glad I could help.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: SB oil filter adapter gasket # [Re: pittsburghracer] #1809410
04/22/15 01:53 PM
04/22/15 01:53 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: SB oil filter adapter gasket # [Re: pittsburghracer] #1809415
04/22/15 02:05 PM
04/22/15 02:05 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I fought what I thought was a rear main seal leak in a 360 I built for my '74 D100. Changed the rear main with the truck on a two post lift, took most of a day to do it and still no joy. Finally it blew out as I lay under the truck watching it run and took a shower in hot oil eek
The new gasket from Mopar was only a few dollars and worth every penny.
I traded that truck to my oldest son for his '69 Chev 3/4 ton and now my youngest son has the Chevy and I wish I still had the old Dodge frown
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
