What paint for dash and doors? #180918
01/01/09 08:46 PM
01/01/09 08:46 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Prepping the Demon dash for paint (doing a color change...brown to black). What paint should I get for this (flat, satin, etc)? It doesn't need to be 100% perfectly original just looking for what most folks use and is easy to spray.
Also, what should I use on the inner door panels?
Re: What paint for dash and doors? [Re: VITC_GTX] #180919
01/01/09 09:14 PM
01/01/09 09:14 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
The metal on the doors of my old 71 dart were a fairly glossy black. The black paint for the dash frame and steering column is weird. It has no gloss to it and almost has a light texture to it.
Some of these colors might be obsolete, but you can take them to a paint store and ask anyways. They might have a modern mixture that is the 'close enough' your looking for.
http://www.tcpglobal.com/aclchip.aspx?image=1971-dodge-pg02.jpg
http://www.restorick.com/tech/topic.asp?TOPIC_ID=41
Re: What paint for dash and doors? [Re: Neil] #180920
01/01/09 09:29 PM
01/01/09 09:29 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks for the links.
I will see of they can get something close.
Re: What paint for dash and doors? [Re: VITC_GTX] #180921
01/01/09 10:26 PM
01/01/09 10:26 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The correct dash & column finish is generally called "suede". If you just want to rattle-can it, there's a "textured" low-gloss black available - Home Depot, etc. It's almost impossible to refinish the top of the dash with the windshield in the car, though.
The door interior surfaces were originally gloss.
Re: What paint for dash and doors? [Re: topside] #180922
01/02/09 01:39 AM
01/02/09 01:39 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks. I think I am going to spray it with my HVLP gun (for practice).
I actually have the dash out of the car as I am refinishing the entire car.
Re: What paint for dash and doors? [Re: VITC_GTX] #180923
01/02/09 10:03 AM
01/02/09 10:03 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
9388 is the correct black for the interior. I can still get the original paint here in KY. It can be had in enamal too if you can't get lacquer. There's no texture to the correct paint.
Re: What paint for dash and doors? [Re: Challenger 1] #180924
01/02/09 11:50 AM
01/02/09 11:50 AM
Arizona
jsully Offline
jsully  Offline
Arizona
Would this also be the correct black for my 70 Challenger dash frame?
Re: What paint for dash and doors? [Re: jsully] #180925
01/02/09 04:01 PM
01/02/09 04:01 PM
Cincinnati, Ohio
Cincinnati, Ohio
Yes
