Re: M body disc, in 71 A body questions.
[Re: ademon]
#1809073
04/21/15 11:29 PM
04/21/15 11:29 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You need to get the adapters that fit the 11.75" rotors. the M body ones are for 10.87" rotors.
You need the control arms, not sure on the lower ball joints, been a few years.
You can run 73 and up A body disc hoses is you mount the calipers like they are mounted on stock 73 and up disc A bodies, otherwise I use 79 F body hoses and remove the bracket.
Run the combination valve off the M body if it has the same diameter rear drums as your A body. The aftermarket adjustable valves are best used to fine tune stock proportioning, if needed. Some will tell you that they work just fine by themselves, those people know nothing about braking systems.
[Re: ademon]
#1809085
04/21/15 11:43 PM
04/21/15 11:43 PM
Supercuda
About to go away
About to go away
up yours
I forgot about those adapters. I need a set for my Cuda, or maybe I'll just buy new control arms, still pondering it right now. Hotchkis makes some nice ones.
[Re: ademon]
#1809124
04/22/15 12:32 AM
04/22/15 12:32 AM
Supercuda
About to go away
About to go away
up yours
Civilian M bodies used 10" rear drums, cops used 11" rear drums, same fronts.
