Anyone use the FBO advance limiter plates? #1808821
04/21/15 07:11 PM
04/21/15 07:11 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang,
Anyone use the FBO timing advance limiter plates? I am experimenting with the timing on my new 426 HEMI and seeing timing, especially initial, has a drastic effect on performance. It appears my hemi likes more initial timing in the 16-18 ranges, maybe more but don't want to push the total advance window past the 34-36 range. With this plate, it seems I can up the initial but keep the total in check while utilizing my vacuum advance functionality.. I recently had my original Presolite dual-point restored with Pertronix guts to be used as a trigger for my MSD6 system. The plate will eventually go in there if it helps.
Troy
Houston Mopar Connection Club
Re: Anyone use the FBO advance limiter plates? [Re: hemi68charger] #1808823
04/21/15 07:13 PM
04/21/15 07:13 PM
BDW Offline
BDW  Offline
I used it, worked as advertised.
Re: Anyone use the FBO advance limiter plates? [Re: hemi68charger] #1808825
04/21/15 07:21 PM
04/21/15 07:21 PM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
Originally Posted By hemi68charger
Hey gang,
Troy, I have used Don's distributors for a while. I like his way of using manifold vacuum to introduce more timing while at light load and then using mechanical when there is little to no vacuum at heavy load. I actually put one in my 472. Haven't been able to drive it due to this brake issue, but the same setup worked great on my 505 stroked six pack motor. Call Don and talk to him about your setup and he'll work with you on what you want. Good guy to deal with, or has been for me anyway! twocents
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: Anyone use the FBO advance limiter plates? [Re: MoparJunkie] #1808911
04/21/15 08:51 PM
04/21/15 08:51 PM
Houston, Tx
Houston, Tx
Just got off the phone with Don.. Nice conversation and I ordered two plates and the documentation and springs... So, we'll see... Looking forward in tinkering with the car..
Troy
Re: Anyone use the FBO advance limiter plates? [Re: hemi68charger] #1818355
05/04/15 11:47 AM
05/04/15 11:47 AM
Houston, Tx
Houston, Tx
Over the past couple of weekends I have taken the Daytona out with the new modifications I did to the electronic distributor I use for my MSD6A trigger. I'm happy to say there are noticeable improvements. The HEMI fires up rather nicely, idles better when cold and the acceleration is MUCH improved. I have some tweeking to do I believe, but I think I have the timing & fuel-air ratio dialed in rather nicely. The setting now is 20 initial using the 14 slots to give me a 34 total mechanical advance.
Troy
Re: Anyone use the FBO advance limiter plates? [Re: hemi68charger] #1818475
05/04/15 02:09 PM
05/04/15 02:09 PM
dogdays Offline
dogdays  Offline
Just to clarify, EVERY vacuum advance distributor uses the vacuum to add timing when the engine is lightly loaded. And the mechanical advance happens regardless of load, acting as the baseline that the vacuum advance adds to.
The magic happens in tuning the two kinds of advance for a particular engine/car combination. Sometimes that's not so easy to do.
R.
Re: Anyone use the FBO advance limiter plates? [Re: dogdays] #2471881
03/25/18 04:53 PM
03/25/18 04:53 PM
NE
moparpoolman Offline
NE
Troy, what did you do for springs in the Presolite Distributor and what RPM does the total advance come in at? Thanks
Re: Anyone use the FBO advance limiter plates? [Re: BDW] #2471922
03/25/18 06:16 PM
03/25/18 06:16 PM
X2 Absolutely the best bang for the buck for limiting mech total. $22 to your door. EDIT has slots for 10-12-14-16 or 18 deg of mechanical allowed.
Re: Anyone use the FBO advance limiter plates? [Re: RapidRobert] #2471941
03/25/18 07:02 PM
03/25/18 07:02 PM
NE
NE
Where do you get one for $22?
Re: Anyone use the FBO advance limiter plates? [Re: hemi68charger] #2471943
03/25/18 07:08 PM
03/25/18 07:08 PM
CA
crackedback Offline
crackedback  Offline
CA
The plates are a very nice piece. Up to $25 now IIRC.
Re: Anyone use the FBO advance limiter plates? [Re: RapidRobert] #2472195
03/26/18 10:25 AM
03/26/18 10:25 AM
middle Tennessee
mopower440 Offline
mopower440  Offline
middle Tennessee
so how do you dial it in to get exactly what you need both initial and total? I need like 18 initial and 34 total on mine..How do you use this plate to get both? Sounds like I need this to replace my old JB weld limiting the ttaol ive had forever..lol
Re: Anyone use the FBO advance limiter plates? [Re: mopower440] #2472200
03/26/18 10:33 AM
03/26/18 10:33 AM
NE
NE
http://www.4secondsflat.com/Mopar%20Mechanical%20timing%20limiter%20plate.htm
The laser etched numbers on the disc designate the amount of mechanical advance so for instance...
If you want 18 degrees of initial timing you just set the plate on the 16* slot 18 initial+16 Mechanical= 34* total
If you want 24 degrees of initial timing you set the plate on the 10* slot for 24 +10= 34* total
If you want to lock down the distributor with NO Mechanical timing at all then just drop the plate over the 0 round hole
Re: Anyone use the FBO advance limiter plates? [Re: moparpoolman] #2472235
03/26/18 12:00 PM
03/26/18 12:00 PM
middle Tennessee
mopower440 Offline
mopower440  Offline
middle Tennessee
Nice! I definitely need this!
Re: Anyone use the FBO advance limiter plates? [Re: hemi68charger] #2472239
03/26/18 12:08 PM
03/26/18 12:08 PM
scratchnfotraction Offline
I agree well worth the 22$ and I got the tuning guide as well.
I have 3 in use now. followed the guide book and wow what a difference it made on my junk.
1)I have in my bone stock 318 a points dist/stock springs/vac pod hooked up full vac and run the initial at 14* with plate set on 18* for 32* total.
runs great on 87 pump gas with no ping and 18mpgs on hwy.
2) 273 points dist/MrGasket light springs/initial on 14* with plate on 18* NO vac pod used.
runs about the same as set up #1
3) 440 230/245 @ .050 whiplash cam-initial set at 34* with plate locked on 0* no vac pod used.
the whiplash cam loves it and made it much more street friendly as a daily driver.
wish I had learned to do this 35 yrs ago.
Re: Anyone use the FBO advance limiter plates? [Re: mopower440] #2472254
03/26/18 12:40 PM
03/26/18 12:40 PM
set the initial with "the vacuum gauge method" then set the total (initial+plate amt) to the std for your eng which will get you close (ie 35 for a SB) then toss the heavy spring with the elongated loop & sub in a MP/mr gasket/transdapt light spring in its place for a start & mix/match from there so you are aways under the pinging point at WOT up thru the gears on your hottest/driest (most likely to ping) day & there is silent ping & peoples' hearing varies so give it a margin. Any spring combo advances in a linear rate no matter which spring you change (once the elongated loop one is tossed). then plug in the can & adj its tip in rate with a 3/32 allen wrench (CCW delays it/takes more in hg to activate it/total amt stays the same) so that you are same as above AWAYS under the ping point in everyday driving under varying load/RPM conditions. there are different cans that offer a different TOTAL available & you can work with the notch on the arm on the can to limit the total in addition to working with the prior tip in rate & this is for PORTED & Don a FBO is a MANIFOLD guru which has a different procedure & many people swear by tho I ain't never tried it (yet) but I was loaned a copy of the "tuning to win" booklet & I was not impressed with it. YMMV
Re: Anyone use the FBO advance limiter plates? [Re: scratchnfotraction] #2472326
03/26/18 03:16 PM
03/26/18 03:16 PM
CA
crackedback Offline
crackedback  Offline
CA
Much better than the set total timing and let initial fall wherever it may per the MP books followers. smile
Re: Anyone use the FBO advance limiter plates? [Re: hemi68charger] #2472464
03/26/18 07:52 PM
03/26/18 07:52 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
Just installed one a couple months back. More initial without the total going into heavy ping range woke my car up considerably.
The design is pretty genius, and hats off to the guy for keeping a fair price instead of gouging customers for it.
Now if only someone would come up with an equally genius/affordable tool to get the top shaft retaining clip out easier. That was seriously the longest part of the process for me. LOL
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Anyone use the FBO advance limiter plates? [Re: hemi68charger] #2472468
03/26/18 08:00 PM
03/26/18 08:00 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
This looks a lot better than welding up the slots then filing them down to get it correct. This takes a long time.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: Anyone use the FBO advance limiter plates? [Re: Bob J] #2472533
03/26/18 10:43 PM
03/26/18 10:43 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
It's clever, but its not better if the engine will be used at high rpm. For high rpm, its better to take advantage of the advance's geometry by shortening the inside (rather than stopping the weight moving at the top).
Re: Anyone use the FBO advance limiter plates? [Re: Mattax] #2472598
03/27/18 01:58 AM
03/27/18 01:58 AM
^^^ I am willing to do this, how does it work better?
