NOISE TOP END 528 RB/MP CRATE #1808654
04/21/15 03:10 PM
04/21/15 03:10 PM
Toronto,Canada
W
wkeggenhoff Offline OP
W
Toronto,Canada
Have over 5000kms trouble free. Have floated vales quite a few times and lifters got noisey. Shut off for few hrs and they pump backup.
The other night had car out driving normal not beating on it at all. Parked it overnight and started car next morning.
Lifters were noisy. Oil level was good, oil pressure 80 psi cold 60 warm. Running 20w50 synthetic oil.
What would cause lifters to loose prime or bleed down ?dID i Damage them by floating them ?
Seems to be coming from both valve covers.
What should I be checking for ? Havent pulled valve covers yet. Scared to drive anymore in case something comes apart.
Thanks Werner
69 dodge charger,528 Hemi,Keisler TKO 5spd, Mosier 60 rear end
Re: NOISE TOP END 528 RB/MP CRATE [Re: wkeggenhoff] #1808662
04/21/15 03:22 PM
04/21/15 03:22 PM
Dang Dude, the motor is talking to you, pull the covers and see what is going on before it gets worse twocents
Re: NOISE TOP END 528 RB/MP CRATE [Re: wkeggenhoff] #1808691
04/21/15 04:03 PM
04/21/15 04:03 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
iagree May not be the lifters. Valves could be coming out of adjustment. There is a reason its making noise.
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: NOISE TOP END 528 RB/MP CRATE [Re: 1320Dart] #1808701
04/21/15 04:16 PM
04/21/15 04:16 PM
P
Porter67 Offline
Porter67  Offline
P
Huh? You might have had 5000km trouble free but the motors not. Ive not had trouble like that since a old 100k 318 with a couple lobes wiped off. But yours is a fresh crate motor.
But as others said, its time to inspect the top end. Adjust and hope you don't have to replace the cam and lifters.
At least your running it hard.
Re: NOISE TOP END 528 RB/MP CRATE UPDATE [Re: Porter67] #1809054
04/21/15 11:08 PM
04/21/15 11:08 PM
Toronto,Canada
W
W
Toronto,Canada
Well pulled valve cover and found pushrod came out from rocker arm. Reinstalled push rod and cranked engine over with coil grounded. There was little to no lift on push rod so figured wiped cam lobe off. Removed intake and found #7 intake lifter shot. Piece broke from inside guts of lifter and it was laying in valley. The cup that holds push rod. Circlip was still in lifter body.
Dodged a bullet I guess.
Re: NOISE TOP END 528 RB/MP CRATE UPDATE [Re: wkeggenhoff] #1809086
04/21/15 11:46 PM
04/21/15 11:46 PM
up You did the correct thing by looking bow twocents
Re: NOISE TOP END 528 RB/MP CRATE UPDATE [Re: wkeggenhoff] #1809115
04/22/15 12:25 AM
04/22/15 12:25 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
My question is : why are you floating the lifters ? Shift that thing. Read the tach, or get a shift light.
