I'm working towards finishing up the brake install on my 72 Cuda. I'm missing one piece to the puzzle.
I need the hose that goes from the rear brake line to the TEE on the axle housing.
All my other hoses are braided, so I'd like to stick with that theme and not just use a stock rubber hose. Besides, the stock replacement with the integral TEE isn't cheap at $40.
What size/type ends should I spec out? I'm trying to find something in the Earl's catalog.
The TEE appears to have 3/8-20 female threads. Is this 1/4" IF?
