Re: Mini alternator?
[Re: RV2]
#1807379
04/20/15 12:35 AM
04/20/15 12:35 AM
Posts: 345 iowa
wesw
iowa
this is the link for the 16 volt alternator. $146.48 [NEW] http://www.bonanza.com/listings/16-Volt-...-Type/226735161if you are running a 12 volt system they have it too. the mount is from mancini racing. P/N BMAB050CT for $125.95 if you run a MSD crank trigger that part is MRECT-30 $43.95
598 ci predator
[Re: RV2]
#1808103
04/20/15 09:35 PM
04/20/15 09:35 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
I had a 55 amp mini for many years. Too small. Went with a 120 amp and my temp back at the pits dropped average 30 degrees because of the higher voltage.
[Re: RV2]
#1808137
04/20/15 10:24 PM
04/20/15 10:24 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Mine in A body w/AR plate and homemade mount. Alternator is from DB Electrical in Tenn. One wire hook up.
If you like drag racing, support your local track.
[Re: RV2]
#1808791
04/21/15 06:16 PM
04/21/15 06:16 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
75A East Coast Elect. here too .One wire hook up.No problems so far.8yrs. Jegs has them.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: RV2]
#1809056
04/21/15 11:15 PM
04/21/15 11:15 PM
CHAPPER
Belpre,Ohio
Don't recall the #,,,,look at their website,,,it was described as being for street rods/drag cars/etc. IIRC it is only like 40 amp, but works for me. My car idles at 1100rpm and it puts out 14.3 volts at that rpm. Search dbelectrical and it should show up,,,they are in Tennesee.
[Re: RV2]
#1836693
05/29/15 02:51 PM
05/29/15 02:51 PM
Thumperdart
State of confusion
I run a mid 80's denso 70 amp from a Toyota 4-runner and it werkz fine for me w/elec water pump, rad fan and ign. box and street driving and cool downs are awesome.
