Re: What choices for drop spindles on a '72 Satellite?
[Re: Hooligan]
#1809255
04/22/15 10:14 AM
04/22/15 10:14 AM
Posts: 721 Seminole County FL to Plymouth...
Barry70GTX
I have the Magnum Force spindles on my 69 Barracuda. 5 years 2 long haul Hot Rod Power Tours later, it's the only way I would lower one. Full suspension travel is the best way.
NMCA NSS 67 Coronet
[Re: Hooligan]
#1809398
04/22/15 01:26 PM
04/22/15 01:26 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
I was away for a few days, but I decided to back off the torsion bar bolts to the max, and the car dropped a good 2 inches! I didn't try it before... thinking not much would happen, but now the control arms and tie rods are level with the ground. The K-member is 6 inches from the ground, and the rubber LCA bumpers are a half inch from the frame. The engine is a 360 6-bbl. (sorry, no car pics yet)
Now I plan to bring the rear of the car down with a home-brewed 4-link set up, and I suppose it would be a good idea to also install tubular upper A-arms to correct the camber and caster issues.
It sure is strange looking down at the car now. I feel like a giant!
Thanks everyone! The camber caster "issue" can be adjusted by getting a new proper alignment. When you change the ride height down or even up like that the alignment changes. When a drag guy raises the front end for weight transfer, header clearance, oil pan clearance, etc, etc he has to get a new alignment too. Tubular upper A-arm have the same geometry as stock one (except for Hotchkis E/B-body). And even then the Hotchkis geometry change is for bumpsteer not ride height. Tubular A-arms are not necessary for lowering you car like that. You can change you lower control arm bumper to shorter ones that Energy Suspension sells: http://www.jegs.com/i/Energy-Suspension/355/9-9102G/10002/-1 Still I would not go too low with stock T-bars. .99" or 1" If you K- member is 6" from ground, you don't sound that low. Need more info though. What is the diameter of your front tires? That number with K-member height gives an idea where the suspension geometry is.
