Re: Best big block rebuild book
[Re: -Cuda]
#1807069
04/19/15 05:58 PM
04/19/15 05:58 PM
Posts: 1,106 michigan
440whiteboy
michigan
Have you tried 'Mopar Engines Manual' - has many combo's to use with lots of pics.
They only see Stars... when hit by a Mopar!
[Re: -Cuda]
#1807286
04/19/15 10:32 PM
04/19/15 10:32 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Doesn't Andy's kind of assume you have rebuilt engines before? I thought i read that somewhere.
Thanks for the suggestions.
Yes, think he did mention that..but as said, I would get and read through a few different ones still for sure. (I've got a bunch of books still and handy to be able to go through different ones for different things)
[Re: -Cuda]
#1807305
04/19/15 10:50 PM
04/19/15 10:50 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
There are a few books out there that can help and add useful information to the factory shop manual. There was a book out about 30 years ago that has some good basic rebuild tips in it. I don't know if you can find it new but I still enjoy looking through it years later. The parts and technology is a little dated but there are some tidbits you may find helpful. Hope this image works Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: -Cuda]
#1807352
04/19/15 11:50 PM
04/19/15 11:50 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
I have them all too. On the MP ones, they have had the same info in them from their first print. If you get a set of old ones, they are just as good as the new. There was also a book done by Chuck Sennatore awhile before Andy's so see if you can find that one too. You can never have enough refference material. Andy's is more up to date and shows lots of street combos. Rockin book!
Carl Kessel
[Re: CKessel]
#1807705
04/20/15 01:36 PM
04/20/15 01:36 PM
dogdays
Really the HP book, "How to rebuild..." is all you need if you're just going to take it apart and put it back together again.
BUT I have to ask why? Many members are running engines that were put together 20 or more years ago, with no problems. Once the gaskets are in place and torqued down, what is going to happen if the engine is in a nice dry shed? I have valve stem seals that are 20 years old or older, NOS, and they are still flexible. The same goes for the other seals.
In this particular case I'd agree with the philosophy of "Don't fix it if it ain't broke."
Use the energy you were going to spend on this project to get a car on the road. I know all about interminable engine projects that never go a foot under their own power. I've done it many times.
R.
[Re: Fab64]
#1807926
04/20/15 05:48 PM
04/20/15 05:48 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I like "How to Rebuild Big-Block Mopar Engines" by Don Taylor. I think I noticed a few errors in it, but it is pretty basic and explains things well. I'm glad this came up. I have this book and a motor that also has been sitting. I'm not bashing the book by any means. I just want to check for oil gallery plugs and what ever else I may need to check before installing and couldn't find this info in that book.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#1807954
04/20/15 06:18 PM
04/20/15 06:18 PM
Posts: 1,074 So Cal, USA
Fab64
So Cal, USA
I like "How to Rebuild Big-Block Mopar Engines" by Don Taylor. I think I noticed a few errors in it, but it is pretty basic and explains things well. I'm glad this came up. I have this book and a motor that also has been sitting. I'm not bashing the book by any means. I just want to check for oil gallery plugs and what ever else I may need to check before installing and couldn't find this info in that book. Oil gallery plugs are mentioned on page 44. He says there are four plugs, and tells where they're located. He goes on to say that the cleaning method will be demonstrated in Chapter 5.
