Re: Pentastar Emblem Placement and Bolt Painting
[Re: Clay Fees]
#1807824
04/20/15 04:01 PM
04/20/15 04:01 PM
Posts: 290 Dayton, WA
wesgtx440
Dayton, WA
There should be 2 holes in the lower part of the passenger fender where the emblem attaches. one is the main pin hole with the locking tabs and the other small pin is just an alignment hole. Fender bolts - body color Door latches - I believe are gold cadmium Door catches - I believe are silver cadmium
68 Charger R/T 440 auto
[Re: Clay Fees]
#1808356
04/21/15 03:25 AM
04/21/15 03:25 AM
wesgtx440
Dayton, WA
If there are no holes, you could just remove the mounting tabs and use some thin double sided tape to mount the emblem?? I cant provide exact location info for a RR fender. Might be able to find a picture on the web and judge where it goes.
[Re: Clay Fees]
#1809163
04/22/15 01:59 AM
04/22/15 01:59 AM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
Here is a photo on a '68 b body fender.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
[Re: jlatessa]
#1809622
04/22/15 06:12 PM
04/22/15 06:12 PM
Challenger 1
Cincinnati, Ohio
Is 6-3/4 a lot further away from 6-1/2 than 2-1/2 is from 2-1/4 ??? Or are my eyes bad, just want someone to check before someone drills!
Joe I think it's because of the dog leg on the fender is tapered?
