Page 2 of 3 1 2 3
Re: whiplash break in! [Re: scratchnfotraction] #1809010
04/21/15 10:18 PM
04/21/15 10:18 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I'm picking up a 60 Dodge Dart Phoenix in a couple of weeks. It's got a good running mystery rebuild 440 in it that I'm looking to tinker on. Currently it's got a stock intake, an edelbrock carb, stock manifolds, points distributor, stock torque converter and 2.76 gears. Mods I'm looking to do are Hedman shorty headers, CH28 intake with dual 9906 AVS's, ported 915 heads, a Petronix ignition, 3.23 sure grip, and possibly a higher stall converter. Also going to see what cam is in it and possibly replace it. Was thinking of a Summitt 6401 but the whiplash is looking pretty intriguing.
One neat thing about this engine is it has an 8 bolt crank, curious to see what else is inside
Re: whiplash break in! [Re: WO23Coronet] #1809024
04/21/15 10:31 PM
04/21/15 10:31 PM
scratchnfotraction Offline OP
sounds cool. 8 bolt crank, now that HD/HP
I am running a 2.76 right now for highway action,and have a 3.23/3.91sg. also have the Edelbrock 440 RPM intake along with the Holley Street Dominator intake.
out of the 6 intakes I tried those two are the keeprs.
the holley is an improvement but looks like a lower PV is needed with it. I only get 5-6 inches of vac in gear at a 750-800 rpm idle. in N it idles close to 900-1000 rpm droping to the 750-800 abrubtly and almost stall then recovers slightly and chops away.
I know it close though.
my 318 gave me fits till I got the right PV in the 650 spredbore holley which is 8.5
IIRC when I rebuilt the 650 dbl pumper I used a 6.5 PV. I think I need to drop down to a 2.5 or 3.0 maybe?
the jets are 70 front/80 rear with 30cc pumps. this was just about perfect for the stock cam but a little rich.
I hope a PV change will fix it up. out of gas and cash at the moment.
Re: whiplash break in! [Re: scratchnfotraction] #1809116
04/22/15 12:25 AM
04/22/15 12:25 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I'd probably consider the 383/400 whiplash, it's abit milder and should have a little tamer idle
Re: whiplash break in! [Re: WO23Coronet] #1811008
04/24/15 04:00 PM
04/24/15 04:00 PM
dropped down to a 4.5 PV, adjusted for highest vac reading in gear = 9.5",
idle in N = 13.5" with slight bounce on the needle at 900-950 rpm,
drops to 750 in gear, and rpm slips up 200-400 rpm on light throttle from a stop.
idles like a funny car and 3" pipes 2chamber muffs are...well LOUD! sounds nasty but LOUD!
I stopped for gas last night and wondered why I got a couple funny looks at store check out with my soda in hand.
I forgot I used to Marlboro filters in my ears for sound control while driving. shruggy
back log pics scope
Re: whiplash break in! [Re: scratchnfotraction] #1811011
04/24/15 04:02 PM
04/24/15 04:02 PM
more
Re: whiplash break in! [Re: scratchnfotraction] #1811103
04/24/15 07:26 PM
04/24/15 07:26 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Looks great. Love the look so far.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: whiplash break in! [Re: scratchnfotraction] #1811206
04/24/15 10:24 PM
04/24/15 10:24 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Originally Posted By scratchnfotraction
dropped
I'd take 13.5" for that combination
hahapriceless
Re: whiplash break in! [Re: scratchnfotraction] #1831778
05/21/15 10:37 PM
05/21/15 10:37 PM
well been reading about PV and tuning the holley.
got the 650 dbl pumper close, but fighting the stock dist with points. I cant get it right.
watching the vac gauge as I cruz around I went back up from a 2.5 to a 7.5 and that seemed to be in the right direction.
get it to cruz, ok but idle sucked, crank up the curb idle, then it on the trans slots. I can dil the timing way back and get the mis-fire out of it but then it is a pig no guts, idle sucks in gear.
then Gorilla hand the wrench and striped the PV threds on the meter block, scratched up another one. made the whole thing way different? removed it and tried 2 holley spredbore carbs 650/800 I cleaned up with a fresh kit only to find both of them are old pieces of POOP! like the rest of my junk.
I "just" Had it close enough to make the cam break in and drive it a 1000 miles to run out of steam on it.
ever want something so bad that when you get it you find it is not as easy as it sounds to "JUST" have it.
no funds for any upgrades to the IGN system, out of carbs so looks like it goes to the back yard again for a while.
Re: whiplash break in! [Re: scratchnfotraction] #1832345
05/22/15 05:47 PM
05/22/15 05:47 PM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Sorry Scratch, they can be disheartening sometimes.
Re: whiplash break in! [Re: scratchnfotraction] #1832471
05/22/15 09:31 PM
05/22/15 09:31 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I just ordered the whiplash for my W200
Re: whiplash break in! [Re: scratchnfotraction] #1832569
05/23/15 12:05 AM
05/23/15 12:05 AM
the whiplash cam is great. break in went fine, over a 1000 miles on it with no hammer time with it skiping/pinging/surging. it is what's in my wallet that is killing me.
I just have to face facts and park it for a bit before something goes wrong it from timing, lean fuel supply ect.
50$ a week budget goes mighty slow just like my truck.
first thing first, so a upgrade for the Ign. system first. cant tune a carb if the timing is whacked.
then on to a new carb that hopefully will be close OOTB if there is such a carb to be had.
so I am in the junking/scraping mood with all my crap piled up to fund the Harley project and save each paycheck for the 440 upgrades while it sits out back.
good thing the whiplash roller cam in the 318 is running like a charm. I don't go near it with a tool and only talk sweet to it.
Re: whiplash break in! upadate? [Re: scratchnfotraction] #1852225
06/18/15 11:38 PM
06/18/15 11:38 PM
first and foremost let me say this is not a rant on hughes cams or firecore. not the issue here. I the tuner am the problem. lack of know how and skills at performance tuning.
well the wait is over. back to square one.
put a brand new edelbrock 750cfm carb on. seems like it will be enough if I ever get it tuned.
wait 1 week
junked both truck projects, I had 1200$ in the two trucks. got 500$ cash.
ordered the Firecore RTR dist/coil/wires/heat shields = 491$ to the door.
wait 10 days
install dist/wires goes smooth, looks good, fire up and start tuning.
yep back to same square one...vac gauge, timing light, any where in the timing tab scale it runs like crap.
advance it out of the scale vac gauge goes up to 10+ idles comes up, revs good drives like poop.
so..? I do the thing I did not want to do (why I bought the firecore RTR dist in the first place) I have to take the brand new dist apart and change springs.
used and scratched up now, first thing DRIVE the collar pin out.
never having done this type of thing before I can see why I never tried. 2hrs getting the thing back together which I think I got it back together right?
much better with the light spring but no sweet spot to be found as far as drivability.
the low vac in gear 7" and 10" in N are no good for the vac pod, so what do I do about that? hook it up to full vac and it drives like poop either way. I see a lot run with out it. I don't get it? how is that done?
I am so frustrated I cant stand myself, I fired me 3 days ago.
so back to square one which = waiting to save up $ again.
I have not had/wanted a drink in 3yrs but after to nights trip around the block being a disappointment, I am ready junk the 440 all together and put the stock 318 back in and buy a bottle of Jim Beam.
OH! right after I save up some cash again.
Re: whiplash break in! upadate? [Re: scratchnfotraction] #1852754
06/19/15 07:58 PM
06/19/15 07:58 PM
Lehigh Acres, Florida
rickstershemi Offline
Sounds like other issues with the moder to me.....never had an engine with no issues that wouldn't run extremely well with:
1. Good Carb
2. Good Fuel
3. Good Ignition
4. Timing Marks Correct
5. Cam Degreed Correctly
6. Dizzy Phazed
Vacuum Leaks...????
Wipe Cam Lobe on Break-in...????
Have you done a leak down or at least ck'd cylinder pressure across all 8..???
Air
Fuel
Compression
Ignition
Try thinking simple and make small changes....????
sorry to hear these woes.....hope to hear better news soon smile
Rickster
Re: whiplash break in! upadate? [Re: rickstershemi] #1852940
06/20/15 12:17 AM
06/20/15 12:17 AM
it gives me just enough that I know it is almost there.
just low speed off idle
checked everything on the list and in good shape there.
I just need a break from it for now. just venting to keep from drinking at the moment.
I know I can do it, just not yet.
Re: whiplash break in! upadate? [Re: scratchnfotraction] #1853299
06/20/15 05:30 PM
06/20/15 05:30 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Mike, please call me. You do not need to take the distributor apart to change the springs. Needle nose pliers and patience. I am installing a Ready to Run and coil in my '73 400 wagon tomorrow. Dead stock. We'll see what happens.
Re: whiplash break in! upadate? [Re: scratchnfotraction] #1853822
06/21/15 03:25 PM
06/21/15 03:25 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
The Performer 750 Edelbrocks aren't very good carbs, lots of guys have issues with them. I've got one on a stock (except for headers) 77 440 and it's not very good. Lean bog when you try to give it ANY throttle from a stop, linkeag is all jacked (secondaries only open approx 1/2 way. I'm replacing it with a Thunder Series 800
Re: whiplash break in! upadate? [Re: WO23Coronet] #1865389
07/06/15 08:47 PM
07/06/15 08:47 PM
seems out of the 5 carbs I have (all 650cfm) will not idle now that I have the firecore dist/wires on. have to jack up the throttle till on transfer slots or main boosters.
got the new OOTB 750cfm performer bolted on it.
changing the advance springs in the dist and this carb got me a good idle, crisp throttle response in N, idle in gear at a redlite with no mis-fire or problems while sitting in gear.
off idle stumble is almost gone but still there. not there when you step down 1/4 throttle.
now I am supposed to limit the mech advance so it does not advance too much at speed/WOT (where it still runs like poop)
cant even grasp how that's done and these "keys" they talk of no one seems to know or have??
so I idle around town and trips to the circle-k just to warm it up good.
I think this is where it will stay. I don't want to go back into the dist. at least I am mobile again with it. slow but mobile.
so it is what it is,looks good, sounds good, runs like poop.
I will settle for the 2 out of 3 and call it done.
back to the Harley project.
Re: whiplash break in! upadate? [Re: scratchnfotraction] #1865444
07/06/15 10:07 PM
07/06/15 10:07 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What happens at WOT?
Re: whiplash break in! upadate? [Re: WO23Coronet] #1865456
07/06/15 10:21 PM
07/06/15 10:21 PM
when I advance it to where it wants/needs to be for base timing, it then has too much mech advance. can get up to 13" vac in N with 10" vac in gear.
so dail it back to where it is correct on total advance with a low base setting for 10" vac in N and 7" vac in gear and have a fair WOT it feels like it is holding back as it builds RPM. drops of vac reading, sluggish, retarded low on power.
this is "JUST" enough vac signal to keep the lightest step-up springs down on idle.
not going to try calibrating the 1407 with a 60$ kit cause with out the advance curve correct there is no use in it.
so it at a spot I can live with.
Re: whiplash break in! upadate? [Re: WO23Coronet] #1865599
07/07/15 12:49 AM
07/07/15 12:49 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Please call my cell tomorrow. Can be done is 2 minutes. 216-224-3667. Thanks, Rick
Page 2 of 3 1 2 3
