Page 1 of 3 1 2 3
anyone run a Purestock/NHRA Blue print 383-B-body? #180746
01/01/09 07:31 PM
01/01/09 07:31 PM
MO
cdp Offline OP
cdp  Offline OP
MO
I'm thinking of building my 383 HP to a Blueprint/Purestock spec. It will go in either a 70-Bee or RR 4spd.
I'm curious about how to get the 9.5 cr. with the limited pistons and CC's.
I think I have the 2315 pistons and the depth is at .105 in the whole. I can't see a 79.5cc head helping much (apx. 8.3).
How do I accomplish this? Do I deck the block .070-.080 to make it work?
Re: anyone run a Purestock/NHRA Blue print 383-B-body? [Re: cdp] #180747
01/01/09 07:49 PM
01/01/09 07:49 PM
Melbourne, Florida
Florida_70Bee Offline
Melbourne, Florida
CDP,
I have done this same combo in my 70 Bee
To get the C.R. up you will need to deck the block and mill the heads and I think Speed Pro offers a correct flatop piston
Here are some specs on my combo
The block is the original std bore 383
I am using the original cast flatop pistons standard bore.
Speed pro plasma moly rings
The block has been decked to a piston to deck clearance of -.006. (NHRA stock elim minimum specs are -.004 (for a 70 383 335hp) in untouched form I measured the piston to deck at -.050
I am using a Fel Pro steel shim gasket for a 413 which has a compressed thickness of .020
The heads are stock unported 906's with stock size 2.08/1.74 valves with a good valve job. Additionally the heads have been milled to 80cc's (the NHRA minimum is 79.5cc's and in untouched form they were 88cc's)
All this adds up to a measured compression ratio of 10.12:1. This number would be higher with a .030 or .060 piston. Originally in untouched form I measured the CR at 8.44:1 (a far cry from it's 9.5:1 advertised CR.
The cam is a Mopar Performance stock resto cam for a 440 6 pack (same dimensions as the original 383 magnum cam except it uses a 3 bolt cam gear instead of the original 1 bolt)
The intake is the unported original.
The carb is the original 585 cfm holley
The converter is a dynamic 11 inch that stalls at 2300 (like the original converter
The ignition is a combination of Mopar Performance elctronic and FBO Ignition Box, and Coil
The exhaust is a TTI 2 1/2 H pipe with Dynomax Ultra Flow Mufflers
I am running a 4.10's in the rear and I am using a pinion snubber and I clamp the front segment of the original springs.
The car weighs between 3975 and 4015 lbs with me in it depending on the fuel load. I leave the line at around 2000 rpms and roll into the throttle (I don't stab it at green as I am running F70-14 Polyglas's) and shift between 5600 & 5700 and it goes through the traps at 5600 rpms.
I hope this helps
Re: anyone run a Purestock/NHRA Blue print 383-B-body? [Re: Florida_70Bee] #180748
01/01/09 08:11 PM
01/01/09 08:11 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I was going to say to get in touch with Andy as his 70 Bee 383 Pure Stocker runs great. But he (Andy) beat me to it. Ron
Re: anyone run a Purestock/NHRA Blue print 383-B-body? [Re: Florida_70Bee] #180749
01/01/09 08:11 PM
01/01/09 08:11 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Wow...what an answer! I think you own the Red-B, right? My block is .040 over and is a new rebuilt short block I got many years ago and never did anything with it.
My intentions were using a 70-B, 4spd that I have now. But it needs a resto. I was thinking of buying an average driver car and doing a switch.
Ironically, my buddy a few blocks away has a 70-B thats 5k original miles. It was hit when new and sat all these years. Its an F5 red, black C-stripe, column shift, bulge hood, post car. We were looking over the motor during tear down and the pistons are way down. He pulled the pistons out before I got to measure the depth. Everything is so nice inside, we're just doiong rings only on the short block and reusing everything but the oil pump, fuel pump, and water pump.
Thanks for all the info!
What are your times?
Re: anyone run a Purestock/NHRA Blue print 383-B-body? [Re: cdp] #180750
01/01/09 08:11 PM
01/01/09 08:11 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
The NHRA spec for the 1970 383 is .004" below deck. I guess you could cut .100" off the deck. I know they used to cut that much off the SS Hemi blocks, but not sure about the 383 blocks.
They also list other legal pistons for Stock. I don't know if all these will work for Pure Stock?
383 60-71
TRW L2315F
TRW L3057F
SEALED POWER 2257P
ROSS 74233
CP PISTONS M17-CP
4916280-CHRY-70[1].rtf (288 downloads)
Floyd Lippencott IV
Re: anyone run a Purestock/NHRA Blue print 383-B-body? [Re: mr_340] #180751
01/01/09 08:36 PM
01/01/09 08:36 PM
MO
cdp Offline OP
cdp  Offline OP
MO
.100 seems like an awful lot to take off. then count for the material taken off the heads to make an 80cc chamber.
How would all the gaskets work out? I'm assuming both mating surfaces of the heads will have to be milled accordingly, and the intake.
How about the top of the block (v-pan rails).
I'm assuming the listed legal pistons all have the same compression height. I think I have the 2315 pistons now.
Re: anyone run a Purestock/NHRA Blue print 383-B-body? [Re: cdp] #180752
01/01/09 08:50 PM
01/01/09 08:50 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Based on what the Florida B said, you might have to bore and hone the block for your pistons and check the deck height before decking the block. It looks like he took off less than .050". As far as the intake faces, you can't cut the intake face on the head into the valve cover bolt holes. The good part about cutting the intake face is that you reduce the port volume. NHRA lists the Minimum Compression Height for these pistons at 1.900". I think the TRW piston is around 1.915" if I remember right.
Floyd Lippencott IV
Re: anyone run a Purestock/NHRA Blue print 383-B-body? [Re: mr_340] #180753
01/02/09 12:21 AM
01/02/09 12:21 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Instead of killing the block move the pin up in the rod .025 and stroke the crank.015.All NHRA spec.Are you sure they are .100 below the deck?
Re: anyone run a Purestock/NHRA Blue print 383-B-body? [Re: scatpacktom] #180754
01/02/09 10:17 AM
01/02/09 10:17 AM
MO
cdp Offline OP
cdp  Offline OP
MO
Yes, checked with a dial indicator last night and a digital calper (.105).
Ironically, my 69.5 440 for my RR is also .105 in the whole. I've heard this is common for the 2266 pistons on a 440.
I was thinking of using the KB162 piston, even though they are not spec'd for NHRA. Decking the block, etc, etc, could get expensive and if I get too much in the motor, I may as well up the compression and go with stealth heads, etc.
I may pull a piston/rod assembly out and compare them to my buddy's stock motor. Its just now been assembled.
NHRA doesn't exactly run events here in KC, but I thought it would be cool to see what a "stock" 383 could really do.
Re: anyone run a Purestock/NHRA Blue print 383-B-body? [Re: cdp] #180755
01/02/09 10:39 AM
01/02/09 10:39 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I thought you wanted to run at the pure stock drags or something I guess Andy answered your question then...About 13.60 at 100mph.Building horsepower to a spec is never cheap
Re: anyone run a Purestock/NHRA Blue print 383-B-body? [Re: scatpacktom] #180756
01/02/09 11:04 AM
01/02/09 11:04 AM
MO
cdp Offline OP
cdp  Offline OP
MO
Well, the short block was already rebuilt when I got it in trade. A real 70 HP 383 thats .040 over. I nice rebuild with receipts, forged pistons, etc. But not balanced or anything.
If it cost 3-5k to get the motor to purestock specs, it may be just as fun and cheaper to do build basically as stock appearing and have fun at the local track.
I'm just now getting started and want to get a feel for what is needed since I've never really checked into it this deep and havn't dragged raced before, but always wanted too.
Thanks for all the input!
Re: anyone run a Purestock/NHRA Blue print 383-B-body? [Re: cdp] #180757
01/02/09 11:42 AM
01/02/09 11:42 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
It wouldn't cost that much from where you are I wouldn't think.No matter what you are gonna want to get the engine balanced.The fact that it wasn't would make me look really hard at the rest of it for quality issues.Having 8 bushings put in the small ends is not that expensive and in your case it would be a win win situation.As it stands right now you have the potential to have a very low compresion dog on your hands
You may spend some money on your heads though
Re: anyone run a Purestock/NHRA Blue print 383-B-body? [Re: scatpacktom] #180758
01/02/09 11:47 AM
01/02/09 11:47 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
http://www.purestockdrags.com/ is where you check out old results and rules and such. Also alot of the guys hang out at V8buick.com in the "Those other guys" section.
Re: anyone run a Purestock/NHRA Blue print 383-B-body? [Re: scatpacktom] #180759
01/02/09 07:19 PM
01/02/09 07:19 PM
MO
cdp Offline OP
cdp  Offline OP
MO
I thought the heads had to be pretty stock. I know I can do a few tricks to the valves and milling, but i'm thinking thats about it.
No matter what I do, the motor will come down and be reinspeced. At this point it is definetaly about an 8:1 motor. I pulled the head and reverified the depth with a .0001/1" travel indicator and got .095".
Did the deck heigth from the factory have quite a bit of tolerance when they were being built?
Re: anyone run a Purestock/NHRA Blue print 383-B-body? [Re: scatpacktom] #180760
01/02/09 07:24 PM
01/02/09 07:24 PM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
This sounds like way too much hassle since you aren't class racing.
A nice idea but why not just do the easy way(s) and go faster?
I want my fair share
Re: anyone run a Purestock/NHRA Blue print 383-B-body? [Re: SomeCarGuy] #180761
01/02/09 07:52 PM
01/02/09 07:52 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Deck height was all over the place from the factory.
Re: anyone run a Purestock/NHRA Blue print 383-B-body? [Re: SomeCarGuy] #180762
01/02/09 09:27 PM
01/02/09 09:27 PM
MO
cdp Offline OP
cdp  Offline OP
MO
This is where the delimma for me is. I could add stealth heads, a stock appearing aluminum intake, a comp. series TQ, shave 200#s off the car and spend about the same $$, look stock, and go faster.
But....
Then its not quite as challenging.
It would be nice to do the Purestock build, but there are no events in the KCMO area. All of them seem to be 500 miles away.
Re: anyone run a Purestock/NHRA Blue print 383-B-body? [Re: cdp] #180763
01/03/09 12:08 AM
01/03/09 12:08 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Is KCMO Kansas City? If it is you have a race in your backyard.Last year we had a race at Gateway.I think it was in May.
Try it you'll love it
Re: anyone run a Purestock/NHRA Blue print 383-B-body? [Re: scatpacktom] #180764
01/03/09 04:46 PM
01/03/09 04:46 PM
MO
cdp Offline OP
cdp  Offline OP
MO
They do have the Nostalgic race here. Chrysler Classic was coming here, but I think quit.
Last year (07), there were a couple of FAST cars. A hemi challenger from KS and I think a Yenko camaro from MO and possibly a mustang. They got rained out just as they were at the line. And that was the race I wanted to see. 08 didn't have any FAST cars. Gateway is about 250 miles from KC, which isn't so bad.
Re: anyone run a Purestock/NHRA Blue print 383-B-body? [Re: cdp] #180765
01/04/09 12:25 PM
01/04/09 12:25 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
i'm not really sure how you'd end up with a set of TRW L2315's down the hole .100+, unless the block was MUCH taller than the 9.98" spec.
as i recall, i decked my block around .035 to get the pistons to .018 above the block(crank stroked to 3.388).
based on your current deck clearance, assuming a typical BB OE chamber volume of 88cc's, and using a steel shim head gasket.....you'd be at about 7.8cr right now.
Page 1 of 3 1 2 3
