MSD Pro Billet Distributor Problem #180734
01/01/09 07:02 PM
01/01/09 07:02 PM
Chapel Hill, NC
O
orangecrush Offline OP
O
Chapel Hill, NC
I pulled my distributor cap the other day to check the rotor and found that inside the reluctor is corroded and the core of the pickup coil is rusted, it looks crappy. What caused this? There has been no water on the distributor or anything else for that matter. Anybody else had this happen?
Re: MSD Pro Billet Distributor Problem [Re: orangecrush] #180735
01/01/09 07:06 PM
01/01/09 07:06 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
It's due to them being ferrous metal and being unpainted/plated. Condensation can form inside the cap because it gets warm and then cools off. Use an old tooth brush with some WD-40 or the like and clean it. Wipe off the dirt and excess spray and repeat this occasionally as necessary.
Re: MSD Pro Billet Distributor Problem [Re: jbc426] #180736
01/01/09 08:17 PM
01/01/09 08:17 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
same thing as mine i just clean it from time to time,down here in the swamp even the tires get rusty.
Re: MSD Pro Billet Distributor Problem [Re: orangecrush] #180737
01/02/09 05:20 AM
01/02/09 05:20 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
this is a common problem afaik and i've found it in my MSD. i think one cause is that high voltage discharges generate ozone in the cap which is highly corrosive
Re: MSD Pro Billet Distributor Problem [Re: orangecrush] #180738
01/02/09 07:57 AM
01/02/09 07:57 AM
Ft. Lauderdale, FL
solarguy Offline
solarguy  Offline
Ft. Lauderdale, FL
Drill a couple of vent holes in the cap to help reduce build up
Re: MSD Pro Billet Distributor Problem [Re: solarguy] #180739
01/02/09 08:11 AM
01/02/09 08:11 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
This has helped a lot on mine.
