Brake Drum/Rotor Puller #1807341
04/19/15 11:39 PM
04/19/15 11:39 PM
USA
Lawn Monkey Offline OP
USA
Anyone have a suggestion for Brake Drum/Rotor Puller for a Dodge 2500 ?
Re: Brake Drum/Rotor Puller [Re: Lawn Monkey] #1807375
04/20/15 12:26 AM
04/20/15 12:26 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
not a 2500 but
i had a really tough one on a chevy impala
went and bought the big drum/disc puller at harbor
and the disc just laughed at it and it did nothing to it.
i ended up taking my varible speed angle grinder with a 4 inch cutting wheel
and i made a relief cut right into the hub towards the bearings and it finally came off.
to me, the puller was a big waste of money.
Re: Brake Drum/Rotor Puller [Re: flypaper] #1809852
04/23/15 12:06 AM
04/23/15 12:06 AM
IN
ahy Offline
ahy  Offline
IN
Not a 2500... smaller vehicle but the same concept may apply. After trying heat, PB blaster and BFH I put a good size 2 jaw puller on and got some good tension on it. Then hit the screw of the puller with the BFH and it came off. Helps to keep some lug nuts on (loose) to catch the parts.
Re: Brake Drum/Rotor Puller [Re: Lawn Monkey] #1810973
04/24/15 03:08 PM
04/24/15 03:08 PM
Guitar Jones Offline
Get new rotors. Remove the axle, then the hub. Place hub face down on wood block, beat rotor off from behind. Reinstall in reverse order.
