Mini alternator? #1807335
04/19/15 11:27 PM
04/19/15 11:27 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Can you guys recommend a mini alternator for racing?
This will be for a big block A body with a motor plate.
I have no problem fabricating a mount setup, I'd like to mount it under the motor plate.
Re: Mini alternator? [Re: RV2] #1807343
04/19/15 11:40 PM
04/19/15 11:40 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run a 75 amp East Coast. If I had to do it again I'd get something bigger. It works but it's on the edge with ignition box, 2 fans, water pump, and lights at night. There customer service has been good.
Doug
Re: Mini alternator? [Re: RV2] #1807346
04/19/15 11:43 PM
04/19/15 11:43 PM
CT
3
340KID Offline
340KID  Offline
CT
Just ordered a powermaster 8162
We are using the AR engine plate and their custom alternator bracket setup, will be mocking up this week.,
Re: Mini alternator? [Re: 340KID] #1807356
04/19/15 11:55 PM
04/19/15 11:55 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
340kid I also bought the AR plate.
Re: Mini alternator? [Re: RV2] #1807379
04/20/15 12:35 AM
04/20/15 12:35 AM
iowa
wesw Offline
wesw  Offline
iowa
this is the link for the 16 volt alternator. $146.48 [NEW]
http://www.bonanza.com/listings/16-Volt-...-Type/226735161
if you are running a 12 volt system they have it too. the mount is from mancini racing. P/N BMAB050CT for $125.95
if you run a MSD crank trigger that part is MRECT-30 $43.95
mancini-racing-low-mount-billet-alternator-bracket-crank-trigger-mount-8.gifMY ALTERNATOR.jpg
598 ci predator
Re: Mini alternator? [Re: RV2] #1808103
04/20/15 09:35 PM
04/20/15 09:35 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I had a 55 amp mini for many years. Too small. Went with a 120 amp and my temp back at the pits dropped average 30 degrees because of the higher voltage.
Re: Mini alternator? [Re: markz528] #1808119
04/20/15 09:56 PM
04/20/15 09:56 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I tried some of the small mini alternators and I found about the same thing on all of them. I even have one for sale. None of the ones I tried will charge or provide even voltage at an idle. If you raise engine rpm, they start charging, but then it falls off again at idle.
My full size 100a unit works very well, but its heavy. I wish I could run a mini, as I have a really nice one for sale, but maybe I will try one of the Mancini 60a units.
Re: Mini alternator? [Re: RV2] #1808137
04/20/15 10:24 PM
04/20/15 10:24 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Mine in A body w/AR plate and homemade mount. Alternator is from DB Electrical in Tenn. One wire hook up.
If you like drag racing, support your local track.
Re: Mini alternator? [Re: Dragula] #1808155
04/20/15 10:41 PM
04/20/15 10:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run a Denso 85a on the race car and on the Rampage on the street..
it will drop off on charge at about 650 rpm.. its a external reg
which I like.. The way I have the sense wire wired up it puts out
14.8 volts pretty much all the time... here is a pic of it on the
race engine.. I have it mounted about the same on the Rampage
Re: Mini alternator? [Re: RV2] #1808256
04/21/15 12:34 AM
04/21/15 12:34 AM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
CHAPPER that is exactly what I want to do.
Re: Mini alternator? [Re: RV2] #1808597
04/21/15 01:49 PM
04/21/15 01:49 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
1 more
Re: Mini alternator? [Re: RV2] #1808791
04/21/15 06:16 PM
04/21/15 06:16 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
75A East Coast Elect. here too .One wire hook up.No problems so far.8yrs. Jegs has them.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Mini alternator? [Re: CHAPPER] #1809052
04/21/15 11:04 PM
04/21/15 11:04 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
CHAPPER do you have a part # for that or an application?
Re: Mini alternator? [Re: RV2] #1809056
04/21/15 11:15 PM
04/21/15 11:15 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Don't recall the #,,,,look at their website,,,it was described as being for street rods/drag cars/etc. IIRC it is only like 40 amp, but works for me. My car idles at 1100rpm and it puts out 14.3 volts at that rpm. Search dbelectrical and it should show up,,,they are in Tennesee.
Re: Mini alternator? [Re: CHAPPER] #1809456
04/22/15 02:57 PM
04/22/15 02:57 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
I just recently installed a small 55 amp powermaster for my drag race only car. Went from having to charge battery every time I came off the track to forgot there was a battery in the car. It stated where the rpm was going to charge and it was correct. Yes these don't charge till 1100-1200 rpm I charge going down the track and return road. Didn't lose any performance works fine for my setup. 340 Auto electric fan, electric water pump, Elec fuel pump, line loc. Tail/ brake lights just a race car I like it. But a bigger engine more electrics everybody is different. Im glad I did should have done it sooner.
Re: Mini alternator? [Re: wesw] #1809562
04/22/15 04:52 PM
04/22/15 04:52 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I would be leary on the Rareelectric alternator. I had a 12v and it lasted less than a year and barely charged the battery. I run this one and like it quite a bit.
http://www.jegs.com/i/JEGS+Performance+Products/555/10171/10002/-1
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Mini alternator? [Re: RV2] #1809744
04/22/15 10:06 PM
04/22/15 10:06 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Thanks for all the info guys
CHAPPER I found it, just typed in street rod in the search bar
Re: Mini alternator? [Re: RV2] #1836332
05/28/15 11:59 PM
05/28/15 11:59 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Well I ran the car last weekend and I got 5 passes in and it died in the staging lanes.
I survived the weekend by putting the battery charger on it after every pass.
Re: Mini alternator? [Re: RV2] #1836381
05/29/15 01:13 AM
05/29/15 01:13 AM
Cab_Burge Online work
Cab_Burge  Online Work
My current bracket car with two group 24 RV/Marine batterys stays charged up by running a 100 amp single wire Powermmaster alternator mounted off of the front motor plate up I will put a slow charge in it with a variable 6 amp charger for several days before racing when the car has set for more than a month to make sure they are both topped off, slow charging batterys at a low rate works a bunch better than a quick charge at a high rate like 30 amps. scope up
Re: Mini alternator? [Re: RV2] #1836693
05/29/15 02:51 PM
05/29/15 02:51 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I run a mid 80's denso 70 amp from a Toyota 4-runner and it werkz fine for me w/elec water pump, rad fan and ign. box and street driving and cool downs are awesome.
