Pitman arm question #180711
01/01/09 06:55 PM
01/01/09 06:55 PM
Inver Grove Heights MN
74RR Offline OP
74RR  Offline OP
I need to replace the ball joint knuckle on the pitman arm of my 74. Is the arm and knuckle all one piece or does the knuckle come off of the arm?
Re: Pitman arm question [Re: 74RR] #180712
01/01/09 07:20 PM
01/01/09 07:20 PM
Kirkland, Washington
Pacnorthcuda Offline
all one assembly, you replace the whole thing
Re: Pitman arm question [Re: Pacnorthcuda] #180713
01/01/09 08:44 PM
01/01/09 08:44 PM
74RR Offline OP
74RR  Offline OP
Thanks,any idea what size nut holds the arm on the shaft?
Re: Pitman arm question [Re: 74RR] #180714
01/01/09 09:06 PM
01/01/09 09:06 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
1 5/16"
