Best big block rebuild book #1807066
04/19/15 05:54 PM
04/19/15 05:54 PM
Silsbee,Tx
-Cuda Offline OP
-Cuda  Offline OP
Silsbee,Tx
I've had a relatively newer rebuilt 440 sitting in the corner of my shop for about 10 years. It was a basic rebuild .30 over, 906s, purple shaft. I've decided to freshen it up before dropping it in with new gaskets. What's the best rebuild with specs book available. I've never rebuilt an engine so a more step by step would be helpful. When I did originally get it running there was no lope. I imagine it was the roadrunner resto cam. I may also decide to go with a more modern cam. I have a Holley street dominator intake I am going to use. I have some Hedman shorties but may go full length over manifolds.
Thx
Re: Best big block rebuild book [Re: -Cuda] #1807069
04/19/15 05:58 PM
04/19/15 05:58 PM
michigan
440whiteboy Offline
440whiteboy  Offline
michigan
Have you tried 'Mopar Engines Manual' - has many combo's to use with lots of pics.
They only see Stars...
when hit by a Mopar!
Re: Best big block rebuild book [Re: 440whiteboy] #1807116
04/19/15 07:07 PM
04/19/15 07:07 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
I like "How to Rebuild Big-Block Mopar Engines" by Don Taylor. I think I noticed a few errors in it, but it is pretty basic and explains things well.
Re: Best big block rebuild book [Re: -Cuda] #1807133
04/19/15 07:22 PM
04/19/15 07:22 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
AndyF here came out with a more 'modern' big block engine book than the Mopar one, might be something to consider as well..
Re: Best big block rebuild book [Re: OzHemi] #1807171
04/19/15 07:54 PM
04/19/15 07:54 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Good point, Oz. penguinhat The Taylor book is from 1994, and Andy's book is currently on my Amazon wishlist.
Re: Best big block rebuild book [Re: -Cuda] #1807279
04/19/15 10:23 PM
04/19/15 10:23 PM
Silsbee,Tx
-Cuda Offline OP
-Cuda  Offline OP
Silsbee,Tx
Doesn't Andy's kind of assume you have rebuilt engines before? I thought i read that somewhere.
Thanks for the suggestions.
Re: Best big block rebuild book [Re: -Cuda] #1807284
04/19/15 10:27 PM
04/19/15 10:27 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Books are fairly cheap. I would suggest that you read them all.
2011 Drag Pak Challenger
Re: Best big block rebuild book [Re: -Cuda] #1807286
04/19/15 10:32 PM
04/19/15 10:32 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Yes, think he did mention that..but as said, I would get and read through a few different ones still for sure.
(I've got a bunch of books still and handy to be able to go through different ones for different things)
Re: Best big block rebuild book [Re: -Cuda] #1807305
04/19/15 10:50 PM
04/19/15 10:50 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
There are a few books out there that can help and add useful information to the factory shop manual.
There was a book out about 30 years ago shruggy that has some good basic rebuild tips in it.
I don't know if you can find it new but I still enjoy looking through it years later. The parts and technology is a little dated but there are some tidbits you may find helpful.
Hope this image works luck
Gus beer
64 Plymouth Savoy
Dana 60
Re: Best big block rebuild book [Re: -Cuda] #1807317
04/19/15 11:10 PM
04/19/15 11:10 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I've got that one too! laugh
Re: Best big block rebuild book [Re: -Cuda] #1807352
04/19/15 11:50 PM
04/19/15 11:50 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
I have them all too. On the MP ones, they have had the same info in them from their first print. If you get a set of old ones, they are just as good as the new. There was also a book done by Chuck Sennatore awhile before Andy's so see if you can find that one too. You can never have enough refference material. Andy's is more up to date and shows lots of street combos. Rockin book!
Carl Kessel
Re: Best big block rebuild book [Re: CKessel] #1807705
04/20/15 01:36 PM
04/20/15 01:36 PM
dogdays Offline
dogdays  Offline
Really the HP book, "How to rebuild..." is all you need if you're just going to take it apart and put it back together again.
BUT I have to ask why? Many members are running engines that were put together 20 or more years ago, with no problems. Once the gaskets are in place and torqued down, what is going to happen if the engine is in a nice dry shed? I have valve stem seals that are 20 years old or older, NOS, and they are still flexible. The same goes for the other seals.
In this particular case I'd agree with the philosophy of "Don't fix it if it ain't broke."
Use the energy you were going to spend on this project to get a car on the road. I know all about interminable engine projects that never go a foot under their own power. I've done it many times.
R.
Re: Best big block rebuild book [Re: OzHemi] #1807911
04/20/15 05:39 PM
04/20/15 05:39 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Often you will find any desired books on Amazon as used at a substantial cost saving.
Re: Best big block rebuild book [Re: Fab64] #1807926
04/20/15 05:48 PM
04/20/15 05:48 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I'm glad this came up.
I have this book and a motor that also has been sitting. I'm not bashing the book by any means. I just want to check for oil gallery plugs and what ever else I may need to check before installing and couldn't find this info in that book.
I have mechanical Aptitude.
I can screw up anything.
Re: Best big block rebuild book [Re: bboogieart] #1807954
04/20/15 06:18 PM
04/20/15 06:18 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Oil gallery plugs are mentioned on page 44. He says there are four plugs, and tells where they're located. He goes on to say that the cleaning method will be demonstrated in Chapter 5.
Re: Best big block rebuild book [Re: Fab64] #1807995
04/20/15 07:24 PM
04/20/15 07:24 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Thanx,
I missed that.
Re: Best big block rebuild book [Re: bboogieart] #1808025
04/20/15 08:14 PM
04/20/15 08:14 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Thanx,
I missed that.
Re: Best big block rebuild book [Re: 440whiteboy] #1808850
04/21/15 07:48 PM
04/21/15 07:48 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
You can't have too many car books. I learned something worthwhile from each of these.
