Re: 71 CUDA ELECTRICAL PROBLEM WITH HEADLIGHT & PARKING LAMPS
[Re: 71redcuda]
#1806808
04/19/15 11:52 AM
04/19/15 11:52 AM
RapidRobert
happened out of the clear blue? any related (electrical) changes preceding this issue? I'd start by pulling the bakelite connector off of the HL switch and pulling the switch out so you can access it's terminals & (1) ohming the switch terminals in the on/off positions you mentioned to see if it is an internal switch issue & (2) jumping fire to the various connector terminals in the bakelite connector & see if the appropriate bulbs light up. this'll point you in the correct general direction to start on if it is the switch or the wireing & www.mymopar.com has the colors for you
[Re: 71redcuda]
#1806979
04/19/15 03:47 PM
04/19/15 03:47 PM
Posts: 2,070 CA
crackedback
CA
Use a factory service manual wiring schematic before any of the ones on mymopar. You could easily check all the circuits by hot wiring the plug. Maybe use a fused jumper to test. Could be a bad switch. If it's not a 100 point show car, put a good headlight relay kit on it. The owner won't regret it! A 71 with one of my kits installed, before and after on low beam.
[Re: 71redcuda]
#1807091
04/19/15 06:37 PM
04/19/15 06:37 PM
Posts: 1,106 michigan
440whiteboy
michigan
Hi everyone,
A friend of mine having some electrical problem with the lamps.. Parking lamps and dash light does not work properly.. When the headlight switch is in 0 position (off) All lights is off. When headlight switch is in 1/2 position ( in the middle ) All lights is still off. (Parking lamps should work when switch is in this position). When headlight switch is turned 3/4 up (almost all the way up) The headlight, parking lamp and instrument panel light works. When headlight switch is in position 1 (all the way up) The headlight works but parking lamps and instrument panel light stop working... Any ideas what the problem can be? Thanks Nicklas-Sweden. I had something like this happen before too. You may want to check all of the grounds. With my car, the side lights ( inside the fenders ) were loose from the under coating. I made a clean grind to metal, then re- tightened those. It did make the blinkers work with the running lights. Also I removed the front headlight wires of the grounds - to grind clean to metal - re tighten the screws helped in my case. Also I found a couple of the bulbs were burned out in the lower valance. sometimes the connector ends get loose of corroded - pull them to see. If key on, you should be able to pull them apart, then back again to see how good the connection is. hope this helps... - -
They only see Stars... when hit by a Mopar!
