How to connect wires in a manual remote mirror to inside?
#1806523
04/18/15 10:42 PM
04/18/15 10:42 PM
Posts: 250 Iceland
BadMoonRacer
Iceland
What is the best/correct way to attach the wires of a manual remote control side mirror from the 60´s to the knob on the inside?
Regards
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials. Icelandic Champion in MC 2007, 2008, 2009 and 2022.
Re: How to connect wires in a manual remote mirror to inside?
[Re: BadMoonRacer]
#1808341
04/21/15 03:00 AM
04/21/15 03:00 AM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
I think those wires are supposed to be permanently attached by the factory with no provision for repair and no repair parts, unless you can duplicate the factory methods. Do you need photos of a working assembly? I can take photos.
[Re: BadMoonRacer]
#1808455
04/21/15 10:33 AM
04/21/15 10:33 AM
Posts: 250 Iceland
BadMoonRacer
Iceland
Hi guys
Thanks for replying. I don´t need photos. My unit is somewhat dissimilar to the one in the photo above. In my case the three cables have been detached from the housing. I am afraid that I will break them when trying to put them again into their respective sockets because I have to pull very hard on them. I thought someone here knew how to put the wires into their sockets without having to pull very hard.
Regards
Ragnar in Iceland
[Re: BadMoonRacer]
#1808628
04/21/15 02:32 PM
04/21/15 02:32 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
As mentioned, that is not usually considered a serviceable part. Being your across the pond, I guess you choices are some what limited. If you have the patients for it, I say go for it.
That metal is kind of soft, maybe you could pry the socket open a bit. Then press them together again once you have seated the cables. Or maybe make a holder and/or put it in a vise, so as to tap them in with a hammer and punch. Be careful though as it's also old and might be brittle.
I have mechanical Aptitude. I can screw up anything.
[Re: D_C]
#1808798
04/21/15 06:25 PM
04/21/15 06:25 PM
bboogieart
Lost and Spaced
I simply found one complete and functional off another car in a junkyard. not so easy to do in Iceland But looking for a good one is probably still the best bet. I've got this one but it's got that stupid blind spot mirror stuck on it.
