383 dip stick lenght #1806409
04/18/15 06:45 PM
04/18/15 06:45 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
Who has a standard 383 dip stick they can measure for me. I just need the lenght from where it sits on top of the tube to the end. Thanks
Re: 383 dip stick lenght [Re: okie] #1806423
04/18/15 07:03 PM
04/18/15 07:03 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
It is a 70 383
Re: 383 dip stick lenght [Re: okie] #1806543
04/18/15 11:12 PM
04/18/15 11:12 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Not sure what you're solving for, but I once had to adjust my dipstick to read accurately. Aftermarket/replacement pan and a new dipstick tube assembly.
Filled pan with 5 quarts, then cut the top off the hollow tube until the oil read 'full' on the stick.
**Photobucket sucks**
Re: 383 dip stick lenght [Re: okie] #1806734
04/19/15 09:46 AM
04/19/15 09:46 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
Just trying to make sure I got the right one in it, it is suppose to be a factory replacment
Re: 383 dip stick lenght [Re: okie] #1806755
04/19/15 10:30 AM
04/19/15 10:30 AM
Indiana
68_661charger Offline
Indiana
My 70 383 dipstick measures 23" from the resting collar to the very tip of the dipstick. 20 3/8" from collar to the full line Hope this helps.
Re: 383 dip stick lenght [Re: okie] #1807035
04/19/15 05:03 PM
04/19/15 05:03 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
OK, Thanks I'll get out there and check it
Re: 383 dip stick lenght [Re: okie] #1808829
04/21/15 07:26 PM
04/21/15 07:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You should be more concerned with where the FULL and ADD marks are than overall length .
Re: 383 dip stick lenght [Re: okie] #1809263
04/22/15 10:25 AM
04/22/15 10:25 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
I am but I got to get it where I can read it, guess I'll get under it and pull the tube and clean the end of it off so it don't wipe it off when I pull it out
