At the time, most all of us had small cube motors, because the rules were weight per cube. You built the engine to match where you thought you could actually make the car weigh. The largest motor I ever had in my car was 457 inches and the last one I was building for those rules, was a 446 inch, B-1 TS motor. I did not run as much KOS as Andy, Leon, Bill, Mike and some of the others, because I mostly concentrated on NMCA and the HOT ROD series and a lot of the dates conflicted. It was fun though and the group that ran KOS for years, was a great bunch of guys. I still see Andy Mayes and Brian Hicks (D-con 1 Challenger) quite a bit. Maybe we should post a KOS thread, let guys post the pics and see if a mod will put a sticky on it like the SS/AH thread.
Monte
