Re: Index racers ---- weight boxes?
[Re: max_maniac]
#1806026
04/18/15 01:57 AM
04/18/15 01:57 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Excuse the mess, street car on Drag Week! I ran it in index classes also, and went with the competition engineering weight box/ battery box, mounted on the opposite side of the trunk from the batteries. Had lead shot in bags 25lbs. and some 10lb. steel weights, etc, will easily hold 200lbs.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: max_maniac]
#1806114
04/18/15 10:00 AM
04/18/15 10:00 AM
Posts: 721 Seminole County FL to Plymouth...
Barry70GTX
I use these weights. They are approximately 10 lbs each and are bolted to the rear most trunk floor through the frame rails. Stuck down the middle of the weights is a T Handle I made to change up to 160 lbs of weight in a couple of minutes. I bought the complete weight bench setup from Habitat for Humanity for next to nothing for the weights.
NMCA NSS 67 Coronet
[Re: max_maniac]
#1806349
04/18/15 04:32 PM
04/18/15 04:32 PM
Posts: 570 Brea, Ca
Dart Racer
Brea, Ca
Used to use weights but two years ago went to the ET Genie http://www.etgenie.com/. Using Crewcheif Pro I am able to adjust the genie to run within a .01 virtually every time. Might be something to look at and is legal in most index classes as it is a manual adjustment done from outside of the car.
[Re: max_maniac]
#1807294
04/19/15 10:38 PM
04/19/15 10:38 PM
Posts: 693 Dunnellon, FL
longram60
Dunnellon, FL
My weight box is a battery box. As you can see, the box weighs 25#. My added weight are bags of tungsten rounds:
1979 AMC Spirit, NHRA Q/SA
[Re: longram60]
#1808489
04/21/15 11:08 AM
04/21/15 11:08 AM
Posts: 6,350 Aurora, Oh.
max_maniac
Aurora, Oh.
Thanks for the idea's guys . I have always tried to adjust the throttle cable or just played the stripe at top end with the brakes and think now I will try to use weight. Looks like a box with some bags of lead shot and maybe use the trunk and maybe a box where the back seat would be to help spread some of the weight around. Russ
[Re: nss guy]
#1808578
04/21/15 01:14 PM
04/21/15 01:14 PM
Posts: 1,212 Minn
SportF
Minn
I "believe" some index racers use the MSD Power Grid and program taking out timing at the start of a run to slow them down. If you look at some of the 60ft times you can see how they slow it down at the start of the run. Is this legal in NSS, NMCA rules? It's not in Victory NSS series. This is the one thing that can completely foul up NSS or any other non-electronic racing. Heck, as far as I am concerned, it will foul up ALL racing. Not only can you slow up 60 ft times, there is a world of "adjustments" that can be made down track. Read articles about "slew rate" in drag racing.
[Re: 64hemi330sedan]
#1808638
04/21/15 02:53 PM
04/21/15 02:53 PM
Posts: 1,212 Minn
SportF
Minn
I SAY IF YOU CAN HOOK A LAPTOP TO IT OR CAN CHASE THE DOTS WITH IT IT SHOULD BE ILLEGAL!. I am with you there!
[Re: SportF]
#1808715
04/21/15 04:33 PM
04/21/15 04:33 PM
max_maniac
Aurora, Oh.
I SAY IF YOU CAN HOOK A LAPTOP TO IT OR CAN CHASE THE DOTS WITH IT IT SHOULD BE ILLEGAL!. I am with you there! Same here I do not agree with allowing the new programmable digital boxes and I also have seen some weird 60ft and 1/8 mile times as compared to the 1/4 mile final ET. However like Jim said the boxes are legal. I did ask once when they started to allow the digital boxes and was told that if anyone is caught at the RACE with the laptop hooked up they would be DQ'd. However who is really going to police that???? I can see and have "heard of" some doing it and if I ever really see them I will speak up. I still run a 6AL digital but not programmable box. Myself I think the digital box has no place in an NSS car. If it gets out of hand I'll just drop out and race points locally
[Re: max_maniac]
#1808737
04/21/15 05:09 PM
04/21/15 05:09 PM
Posts: 289 Lowes
steve660
Lowes
Thanks for the idea's guys . I have always tried to adjust the throttle cable or just played the stripe at top end with the brakes and think now I will try to use weight. Looks like a box with some bags of lead shot and maybe use the trunk and maybe a box where the back seat would be to help spread some of the weight around. Russ If all your trying to do is slow it down why don't you just lower your shift points?
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
