I had waited on the holley hydramat and then found their prices a bit crazy.
I had posted about this over the radium surge tanks a while back and decided for the money saved, I was willing to give it a try.
surgetank 320 with shipping and the nipple fittings. Which turned out to be banjo fittings, so I would not do that again. I would order regular fittings at 7 bucks each instead.
it takes a bosch 044 pump, and again trying to save a buck I went with the TRE pump instead.
pump direct replacement and 100 bucks cheaper. 90 bucks with free shipping.
I have one of their other pumps, been running it a few years, so figure it was worth the risk on a non-oem pump.
I have to say first off, was no impressed with the surge tank shipping time. took 2 weeks from order to get it.
the TRE pump on the other hand was super fast. ordered Saturday, shipped monday and I got it just now.
there were some minor scratches inside the tube of the surge tank. Seemed to be below the o-ring so I let it go.
all said and done, new pump and surge tank still are around 400.
the cheapest radium is 460 for one that takes an internal pump. the external pump is around 380. and neither count the pump.
Assembly kind of sucks. wiring is integrated and worked nice. But to get the ends on, you basically have to thread it into the pump to pull the ends together.
you may have noticed in the picture, there is no protrutions. nothing to lock a vice on without messing up the finish.
you basically have to grab it and put a wrench on the end and hope you have good grip strength.
not real fond of that assembly method. Taking it apart also seems to be a pain. same issue, trying to hold it steady and wrench an end off. you cannot do it by hand at all.
Then since the ends are not synced, you have to figure out how to clock it so that the feed is at the bottom and, in my case, I wanted the hole for the return back to the tank on the other side of the surge tank so there was no chance for bubbles to accumulate near the inlet of the pump. so you get to figure out just how far you can tighten it to line up the holes like you want.
Haven't put it in the car yet. but plan on trying this weekend.
