Cant make out the numbers on this alternator #1805720
04/17/15 05:11 PM
04/17/15 05:11 PM
Tacoma, Washington USA
Adam71Charger Offline OP
pulled this alternator from a 78 400 truck motor. Want to know the amperage, I think its a 60amp but cant make out the numbers. looks like 3874__2-5
Re: Cant make out the numbers on this alternator [Re: Adam71Charger] #1805738
04/17/15 05:29 PM
04/17/15 05:29 PM
CrazyD Offline
CrazyD  Offline
3874992-5
here is a pic of one on ebay
Re: Cant make out the numbers on this alternator [Re: Adam71Charger] #1805752
04/17/15 05:51 PM
04/17/15 05:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I think the numbers you want will be stamped on a flat area. I don't know if the casting numbers you have there will identify the amperage.
Re: Cant make out the numbers on this alternator [Re: stumpy] #1805762
04/17/15 06:14 PM
04/17/15 06:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
iagree The casting number was used with most units regardless of amp rating...the stamped number will identify the exact application.
Re: Cant make out the numbers on this alternator [Re: Adam71Charger] #1805765
04/17/15 06:17 PM
04/17/15 06:17 PM
ok, didnt see any stamped Ill double check.
Re: Cant make out the numbers on this alternator [Re: Adam71Charger] #1805785
04/17/15 07:00 PM
04/17/15 07:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Look on the ears.
