Re: 400BB build up
[Re: Volare4life]
#1658782
02/15/15 03:35 PM
02/15/15 03:35 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Having built Many of these, my .02 is not to Over-think these things. for a high torque 550-670'is horse motor theyt can't be beat. Find a good solid block like this one 71 230 but not a cold weather uber-thick main and drop in a 4.15 to 4.30" crankwith a decent st of 280-320 CFM heads with a streetable 250-265 ish @.050 cam and let it go; there's really not much point making more top end power if you can't make the torque you already have hook up. The best, most reliable motors are the ones that keep the torque peak in the 3800-4400 RPM range, when you really turn up the wick with big 360-380 cfm Max Wedge heads they can make 675-725+ HP but it requires a lot more spring/cooling/converter and tire to really make it pay off and 90% of people won't even know the difference between a 620HP and 720HP motor below ~5000 RPM anyway. Torque is what sets you back in the seat and as strong as B/RB blocks are they are (after all) 2 bolt main motors designed for modest RPM torque peaks... If you think about it....there's a reason Hemi's had/have cross bolted Mains....durability.
I'm not saying you can't build a reliable 700 hp motor and drive it on the street, it';s just that it generally costs a lot more to achieve a powerband improvement that is usually only appreciated above an RPM you (for most people) seldom get to use outside of a drag strip.
Again, don't over-think things, build it the way you want it, this is the Race forum so (although well-intentioned) a lot of what you'll hear on this forum will lean toward "super-sizing" the build. You can, but don't feel you need to. MHO only
Re: 400BB build up
[Re: Volare4life]
#1805441
04/17/15 05:24 AM
04/17/15 05:24 AM
Posts: 119 Jacksonville , Fl
Volare4life
Jacksonville , Fl
so after having several issues with timing, running the coyles "tru roller" double roller timing set up. and changing out to a msd blaster 3, she fired right up. And all was right with the world, until it started bubbling and geysering water from the radiator. immediately shut it down, had no clue what could have caused it. oh joy time to trouble shoot, so here we go down the rabbit hole;
So the radiator is a thicker 2 core out of a 80's ramcharger with ac, copper/brass, capped it put a gallon of distilled vinegar and topped it with distilled water, gave it a 5-10 minute shakey shake, let it sit for an hour vertically so all the crap would settle at the cap, did that for about 4 hours, got it nice and clean before the install.
****TSTAT WAS OUT THE WHOLE TIME OF BREAK IN******plugged the lower rad hose and filled up the block with garden hose water, once full popped the plug and continued to flush block the best I could to get all the crap out.
best thing I can figure is the arp head studs need a retorque, and the main reason I went with studs instead of bolts is a better clamp load, and yes I cleaned, cleaned cleaned the crap out of the bolt holes, bottom tapped them, arp lubed them.
Once I get off watch I am going home, tearing it down to get to the studs, torque checking them and if any turn break them all loose and retorque them, put back together and fire it up......again and pray it fixed the exhaust in the coolant, weird thing was car didn't miss a beat, no knock or ping, nothing, hell we'll see. still need to get the wide band hooked up ( weld the bung in place ) and get my tune on
and as always thank you everyone for the continued help with this project -Mike
The answers are out there you just got to look hard enough
Re: 400BB build up
[Re: Volare4life]
#1805673
04/17/15 03:39 PM
04/17/15 03:39 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
How long and what RPM did you run it at before the troubles started?
Re: 400BB build up
[Re: Volare4life]
#1805864
04/17/15 09:22 PM
04/17/15 09:22 PM
Volare4life
Jacksonville , Fl
only about 5 mins, just set timing at 2,500rpm 34deg vac plugged on carb and dizzy ( fire core vac dizzy not the RTR), thought it could have been a hella air bubble trying to burp out, but it didn't seem right so i shut it down and it kept spewing brown *EXTREMELY HOT WATER* every where, I just finished retorquing the head studs to 80 ft/lbs per ARP instructions, all but 2 moved, started it back up same issue, belt not hooked up and still puking fluid out of the rad fill hole, so heads are coming off, off to the shop for a magnaflux and pressure check, i may say f it and quite wasting money on these iron heads and go with some 440 source heads,
-Mike
Re: 400BB build up
[Re: Volare4life]
#1807109
04/19/15 06:58 PM
04/19/15 06:58 PM
Volare4life
Jacksonville , Fl
Dustmite it would be appreciated, but I plan on ripping it down tonight to get the heads ready for turn in tomorrow, I thought it might have been a wicked air bubble as well, but with the water pump/ alternator belt off it still gurgles and pukes from the rad. Dave I hope its just a gasket problem, other wise it might be time to pull the trigger on a set of 440source heads, already have about $400 in the iron heads
-Mike
Re: 400BB build up
[Re: Volare4life]
#1810347
04/23/15 07:03 PM
04/23/15 07:03 PM
Volare4life
Jacksonville , Fl
so they magnafluxed the heads again, and still good, double checked the flatness, still good, so i got another set of felpro blues, lets see if if this works, thinking about making sure the studs are a bit more then hand tight this time, and running a torque check at least twice before i fire it up again, trying what the shop suggested and sprayed them with copper coat, lets hope all is right this time. also I noticed the cooling holes in the gasket are just tiny slots, should i use a hole punch and atleast punch them out round to max coolant flow through the heads ?
Re: 400BB build up
[Re: Volare4life]
#1831738
05/21/15 09:49 PM
05/21/15 09:49 PM
Volare4life
Jacksonville , Fl
its coming, had issues with the rag joint and 1 7/8" hooker headers, that's a post in and of its self, just been working alot more than normal ( thanks navy training squadron), but I am shooting to have it up and running this weekend, and hopefully fixed its coolant demon
Re: 400BB build up
[Re: JeffL]
#1832254
05/22/15 03:27 PM
05/22/15 03:27 PM
Posts: 4,432 Michigan
MarkZ
Worthy
Worthy
Sorry to hijack...
Jeff, what headers are those? I'm stuffing a BB into my M body and the engine compartment is exactly the same as an F. Are those shorties?
Very clean install!
Thanks...
Re: 400BB build up
[Re: Volare4life]
#1849874
06/15/15 08:15 PM
06/15/15 08:15 PM
Volare4life
Jacksonville , Fl
well I am stuck like chuck, the rusty color all over everything is from the radiator and block flush/ first explosion of water. So I have kept having problems with what i assume is head gasket issues, but now i am thinking more head issues, and not willing to go aluminium just yet ($1,000 is a big chunk just to throw at something for trouble shooting) but if thats what will fix it, heres the story in the short, -73 vintage block .040 over -906 heads decked to clean up -block decked to clean up -calculated comp is right around 9.8-1 -stock length eagle h-beams -KB 240 hyper pistons -383 forged crank cleaned up stock specs - felpro gasket kit (felpro blue gaskets) -GMB aluminium WP -440source aluminium pass side water pump housing -ARP bolts for mains -ARP head studs - firecore dizzy and wires first issues with was on first start, brought up rpms for break in, then water puked from the rad filler neck, I just figured huge air bubble, shut it down to cool continued to try and burp it, nothing was working. disconnected wp/alt belt and it still was puking from the rad filler neck, not good, pulled off the valve train and retorqued the head gaskets ( installed finger tight with the arp lube, on re torque #3 i broke them all loose snugged them down with an allen key, then retorqued them) and still same issue. ripped the heads back off the motor, took them back to the machine shop, had them go through them again, re magna flu them, and still all checks good. put it all back together, except this time copper spray the gaskets, and now all seemed right with the world. except now it still does this...... [video:youtube] https://youtu.be/GO94yMbJUiU[/video] and the [censored] is driving me insane, and no i broke the mic on my iphone so no sound, but still shows how even theres no belt it still bubbles and gurggles, also once shut it down, refilled it with water, put the radiator cap on, drove it around the front yard, parked it and shut it down, i could hear an audible hiss from the passenger side right around the 4-6 cylinder region, which has me thinking i have a crack in a water jacket, but...... no water in oil no oil in water no visible water leaks no "white smoke" or any smoke/water vapor from either muffler I am really getting irritated with this, like to the point of selling it and going back to the boosted slant, kinda pissed... but jesus i have so much $$$$$$ into the build, and so much $$$ into the iron heads, I need help guys, and if your in the local jacksonville, fl area feel free to come by, i have a beer fridge in the garage lol -Mike
Re: 400BB build up
[Re: Volare4life]
#1850181
06/16/15 01:32 AM
06/16/15 01:32 AM
Posts: 5,163 CT
GTX MATT
CT
Is there a thermostat in it? What kind of radiator?
Are you running it with the cap on it first? And it starts to overflow? Or?
Re: 400BB build up
[Re: Volare4life]
#1850447
06/16/15 01:48 PM
06/16/15 01:48 PM
Posts: 5,163 CT
GTX MATT
CT
Hmmmm missed the part with the heat crossover. It would seem that its cracked where the heat crossover is. If you were close I'd lend you a set of stock heads to bolt on and see if they work.
Re: 400BB build up
[Re: Volare4life]
#1850475
06/16/15 02:18 PM
06/16/15 02:18 PM
Posts: 336 Creston, Iowa
340man4ever
Creston, Iowa
I had a similar experience with a 360...heads were milled.......decks milled......ended up the intake needed corrected for proper fitment...... acted and sounded just like you are describing
Curator at Adams County Speed Shop
Re: 400BB build up
[Re: 340man4ever]
#1850505
06/16/15 02:59 PM
06/16/15 02:59 PM
Posts: 5,163 CT
GTX MATT
CT
I had a similar experience with a 360...heads were milled.......decks milled......ended up the intake needed corrected for proper fitment...... acted and sounded just like you are describing On a small block it would make sense, but remember, big block's don't flow coolant through the crossover
