HELP s.o.s rear spring-shackle mounts Dr. DIFF?????? #180546
01/01/09 04:48 PM
01/01/09 04:48 PM
wisconsin
swifter Offline OP
swifter  Offline OP
wisconsin
O.K here is car-1970 340 duster with a 67 b-body 83/4 rear-end here is the problem!!!! the mount shakles that came with the car had the hard plastic bushings so i ordered new shackles with the rubber bushings,the first set the bushings fit the spring eyes but not in the upper spring mounts???? so i ordered new offset shakles because of the 67 rear end went to put them in today SAME PROBLEM the bushings do not fit the upper rear spring mounts-This is giving me grey hair and i,m beside myself it seems this should be so easy how many differant spring mounts are there for a 70 a-body also i now noticed that on the driver side i have a spring with 4 leafs and on the pass side i have 5 leafs i was told that hese were new super stock springs is or are these correct HELP--Swifter This is my first mopar project and am ready to be DONE!!!
2007 Ram 2500 Cummins 2008 Dodge Nitro 1970 340 Valiant Duster
Re: HELP s.o.s rear spring-shackle mounts Dr. DIFF?????? [Re: swifter] #180547
01/01/09 09:57 PM
01/01/09 09:57 PM
abodyman Offline
super street
abodyman  Offline
super street
If Your writing about the REAR rubber bushings for your leaf springs, then the ss springs have the larger hole.
The stock a body hole is smaller.
for the stock leaf springs.
You said You had super stock springs so then the rubber e or b body bushings will work. for the springs... and the stock a body bushings should work for the upper bushings.
Re: HELP s.o.s rear spring-shackle mounts Dr. DIFF?????? [Re: swifter] #180548
01/02/09 02:40 AM
01/02/09 02:40 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
What do your shackle bushings measure? A-bodies used 7/8" OD pieces.
