O.K here is car-1970 340 duster with a 67 b-body 83/4 rear-end here is the problem!!!! the mount shakles that came with the car had the hard plastic bushings so i ordered new shackles with the rubber bushings,the first set the bushings fit the spring eyes but not in the upper spring mounts???? so i ordered new offset shakles because of the 67 rear end went to put them in today SAME PROBLEM the bushings do not fit the upper rear spring mounts-This is giving me grey hair and i,m beside myself it seems this should be so easy how many differant spring mounts are there for a 70 a-body also i now noticed that on the driver side i have a spring with 4 leafs and on the pass side i have 5 leafs i was told that hese were new super stock springs is or are these correct HELP--Swifter This is my first mopar project and am ready to be DONE!!!
