I own a stock 1968 Dodge Dart 270 that I am converting into a 1968 Dodge Dart Hemi Super Stock.
I recently purchased a fiberglass lift off hood and the correct hood pin kits.
I am trying to obtain knowledge on the exact location of where the Hurst factory installed the rear hood pins on their 1968 Dodge Dart Hemi Super Stock's.
If someone has access to an actual 1968 Dodge Dart Hemi Super Stock, can you obtain accurate measurements of the rear hood pin locations and also the location of the front hood pins? If so can you also take a photograph of the measurements and post the image(s)?
Thanks!
