manual steering ? #180459
01/01/09 03:13 PM
01/01/09 03:13 PM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
I'm thinking of changing to a manual steering gearbox in my 71 Dart. Does it matter what the gearbox comes out of? A,B,C,E, truck, van.
Re: manual steering ? [Re: alpha727] #180460
01/01/09 03:16 PM
01/01/09 03:16 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Not sure but don't forget you"ll have to change steering columns or shafts also.
Re: manual steering ? [Re: stumpy] #180461
01/01/09 03:18 PM
01/01/09 03:18 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
or u can get an adapter from flaming river and leave your steering column alone.
Tony
70 AARCuda Vitamin C
Re: manual steering ? [Re: alpha727] #180462
01/01/09 03:22 PM
01/01/09 03:22 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
The manual box in my 65 Coronet is from an A body. The outer shell of the column doesnt need to be changed usually, just the shaft. (easy to do really) Youll likely need a pitman arm for your car for a manual box. I didnt check to see if the power steering pitman arm fit the manual box.
IIRC A,B, and E body cars share the same manual box. Likely though the most common manual steer box will come from an A body as many more A bodies came with manual steering and B or E bodies.
Doc.
Re: manual steering ? [Re: NTOLERANCE] #180463
01/01/09 03:37 PM
01/01/09 03:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
There was a pitman arm change in 73 so the early arm and the late arm won't interchange. On need to watch the way the stud from the arm goes throught the drag link also. Some come up and some go down.
Re: manual steering ? [Re: NTOLERANCE] #180464
01/02/09 02:00 PM
01/02/09 02:00 PM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
That is just the reason I love this site so much. So, you're saying I can find a floor shift power steering column to replace my column shift unit then just find the steering shaft from a manual steering car whether it's three on the tree or AT column shift to complete the conversion. I got a little confused about the pitman arm though. Which pitman arm do I need manual or power?
Re: manual steering ? [Re: alpha727] #180465
01/03/09 10:43 PM
01/03/09 10:43 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Yes and Yes on the steering column. Any manual shaft will fit any "tube" for a given year/model.
As far as the pitman arm, I "THINK" they are different manual to power, but dont quote me on that. Perhaps someone who has put a power pitman arm on a manual box will chime in.
Re: manual steering ? [Re: NTOLERANCE] #180466
01/04/09 08:43 AM
01/04/09 08:43 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I've swaped the PS pitmanarm to the manual box during changeovers.
