Re: 440 3/8 pushrod interference
[Re: paulsplymouth]
#1804729
04/16/15 03:10 AM
04/16/15 03:10 AM
Posts: 43,204 Bend,OR USA
Cab_Burge
I use different thickness rocker arm shims, they come in .015, .030 and .060, to space the intake rockers away from the intake ports on the heads and to help center and align the rocker arm tips on the valve stems IHTHs
[Re: Cab_Burge]
#1804745
04/16/15 04:34 AM
04/16/15 04:34 AM
RapidRobert
What Dog said, I'd want more, for me maybe 30 tho at the closest point
[Re: RapidRobert]
#1804764
04/16/15 06:45 AM
04/16/15 06:45 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Just remove the heads and ream the passage out for your clearance. It isn't rocket science.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
