Re: 727 downshift limit valve (part throttle downshift) help
[Re: VITC_GTX]
#1804284
04/15/15 05:09 PM
04/15/15 05:09 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Installing the '71 and later PTK module is pretty much a straight bolt-in, remove the end plate and install the module and its end plate. One of the screws that holds the steel separator plate to the aluminum transfer plate will interfere with the installation of the PTK module, simply remove and discard the screw. The limit valve won't be operative because the early VB's lack a sense port for it but the PTK will work fine.
The PTK from an earlier /6 trans can also be used (second pic)
[Re: VITC_GTX]
#1804299
04/15/15 05:29 PM
04/15/15 05:29 PM
John_Kunkel
Rio Linda, CA
The limit valve in the newer PTK module limits PTK to below 40 mph. Either one works but the later unit is easier to find.
The VB needs to be removed to perform the installation.
