91 dakota carb?? #180393
01/01/09 12:19 PM
01/01/09 12:19 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
If I put a thermoquad on my 91 dakota will the tach and all the other instruments still work?
Re: 91 dakota carb?? [Re: HotRodDave] #180394
01/01/09 01:02 PM
01/01/09 01:02 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
NO...I'm pretty sure the tach gets it's signal from the computer. If you are running a carb, I assume you are doing away with the comp. and also need to install some sort of electronic ignition to bypass the crank sensor. If you find a way to just run a carb without completely disconnecting the computer, then the tach would probably still work.
I am running a thermoquad on my 92 Dakota but I installed a 400 and got all new gauges. One thing I did luck out on though was that the A/C compressor clutch still works with no computer.
Re: 91 dakota carb?? [Re: HotRodDave] #180395
01/01/09 01:49 PM
01/01/09 01:49 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
you may get some help from dodgetrucks.org
