preferred 360? #180387
01/01/09 12:11 PM
01/01/09 12:11 PM
West Tennessee
rbstroker Offline OP
West Tennessee
Is there a preferred year/model 360 engine to easily swap into an early mopar from a 273/318?
This is the land of the free because of the brave
Re: preferred 360? [Re: rbstroker] #180388
01/01/09 12:14 PM
01/01/09 12:14 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
They're all about the same to physically install...need the 360 specific oil pan, harmonic balancer, and the special balance weight on the torque converter or flexplate. and a driver's side motor mount.
If I were picking one, the dodge truck 360 magnum or an early 70's 360. The magnum will make the most power but would likely require a bit more parts swapping, which is not a big deal.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
