Re: 2002 Grand Caravan Strut Nut Remove/Install?
[Re: CompSyn]
#1802675
04/13/15 09:16 PM
04/13/15 09:16 PM
Posts: 21,446 It's a dry heat
gtx6970
It's a dry heat
I usually just grip the shaft with a good pair of vice grips. I think the nut is maybe a 21 mm....aftermarket nuts are different size. ...but vary from manufacturer to manufacturer.
To be honest..that past few sets I've done I just get the loaded versions
[Re: gtx6970]
#1802807
04/13/15 10:49 PM
04/13/15 10:49 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
To be honest..that past few sets I've done I just get the loaded versions I may try the vice-grip option for removal if I can't round up an impact gun. Curious, how did you tighten the nut on the new strut? I strongly considered quick-struts. Some report satisfactory results, others not so much. I was concerned about installing new springs in the front as where the rear OE leaf springs would remain. For example, one guy said his new quick-struts raised his ride height by two inches. Although, I'm sure new springs would probably settle over time, I didn't feel like rolling the dice on that one. Currently, my ride quality is not too bad and no sagging that I can detect so I'm hoping my OE front springs will get a few more miles out of them.
[Re: CompSyn]
#1803064
04/14/15 08:44 AM
04/14/15 08:44 AM
Posts: 10,735 North Dakota
6PakBee
North Dakota
.....I may try the vice-grip option for removal if I can't round up an impact gun. Curious, how did you tighten the nut on the new strut?..... It's been a while but I think I just assembled the strut and ran the nut on with an impact. The torque is only about 70-75 lb-ft as I recall so you don't want to get carried away. Once the strut was in the vehicle and the spring compressor released, I checked the torque with a torque wrench without holding the shaft. Seemed to work. I've got another 100,000 or so on it since I did it.
[Re: CompSyn]
#1804092
04/15/15 12:38 PM
04/15/15 12:38 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Two things. if you need to know the size of a nut and can get an adjustable wrench on it you can measure the gap in the wrench's jaws to tell what size socket you need.
Second, I never use an impact to loosen a strut nut, no need. Just loosen the nut first thing before you jack the vehicle up. The weight of the vehicle will hold the shaft in place. Loosen only, don't remove it. yeah an impact makes it easy but if you don't have one it's not a show stopper.
[Re: Supercuda]
#1804186
04/15/15 02:29 PM
04/15/15 02:29 PM
CompSyn
Pacific NW USA
Second, I never use an impact to loosen a strut nut, no need. Just loosen the nut first thing before you jack the vehicle up. The weight of the vehicle will hold the shaft in place. Loosen only, don't remove it. yeah an impact makes it easy but if you don't have one it's not a show stopper. Good suggestions, but given the application, neither is possible.
[Re: CompSyn]
#1806031
04/18/15 02:04 AM
04/18/15 02:04 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
one guy said his new quick-struts raised his ride height by two inches. Interesting complaint because my 2 experiences with quick struts was the same. Gained major ride height.
