caravan starter ? #180376
01/01/09 11:48 AM
01/01/09 11:48 AM
moparx Offline OP
moparx  Offline OP
can anyone tell me if the bosch[solinoid style] and the nipondenso [gear reduction style] will interchange on 3.0/3.3 engines ? say 95 -2005 engine range ? i know there is a slight wiring connector difference. thanks in advance !
Re: caravan starter ? [Re: moparx] #180377
01/01/09 01:28 PM
01/01/09 01:28 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
I think the 3.0L has a three bolt mount and a 3.3L has two. Any 3.0L should fit a 3.oL and any 3.3L should fit a 3.3L, wiring may need some altering but nothing major. ps most of the time a contact in the solinold goes bad, if you are near a starter/generator shop it not a big fix.
Re: caravan starter ? [Re: SALEM1912] #180378
01/01/09 01:49 PM
01/01/09 01:49 PM
moparx Offline OP
moparx  Offline OP
thanks for the reply. my fsm sort of indicates the same starter is used on all engine options, but is not real specific. i remember swapping out this setup one time before, but i don't remember which engine it was. i don't have starter problems, but i have a fairly new starter on my old bus, and was going to put it on the shelf for future use just in case. any other opinions ?
Re: caravan starter ? [Re: moparx] #180379
01/01/09 02:49 PM
01/01/09 02:49 PM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
After a quick research on Autozone.com, the parts numbers for starters for a 95 caravan with a 3.0 and a 3.3 are different starters. Also, for 2005, there is no 3.0 available and the 3.3 starter is different than the 95 starter, or at least they all show different part numbers.
