Re: green bearings
[Re: MoparforLife]
#180366
01/01/09 11:21 AM
01/01/09 11:21 AM
Posts: 1,791 Big Sky Country
MO_PA
Big Sky Country
Many were used OEM
Did Chrysler (OEM) use ball bearings on the rear axel? Or are you refering to GM.
Re: green bearings
[Re: MO_PA]
#180367
01/01/09 11:39 AM
01/01/09 11:39 AM
Posts: 1,320 Lees Summit, MO
BrianT
Lees Summit, MO
I think ford and Toyota used them from the factory. I have them in my street driven dart BTW.
1970 Duster 340 clone
Re: green bearings
[Re: Mopar1]
#180370
01/01/09 03:16 PM
01/01/09 03:16 PM
Posts: 6,097 Valencia, España
NachoRT74
Valencia, España
well I have to say what I think mostly of ball bearing axles are not pressed in axle I think, they are simply fit between axle and housing like any regular bearing, and then the C clips at the end, into carrier, doesn't need adjust from one againts the other so never a side load against bearings cups, at leats not like the 8 3/4 design. On ball bearings design WITHOUT C clips at the end, maybe you get more load on bearings than regular assemblies with C clips, so is being just holded by the pressure itself with axle. I know,is something extreme, but something to think about depending on where ( town characteristics ), and how you plan to drive it
