looking for advice on 470 #1803579
04/14/15 09:16 PM
04/14/15 09:16 PM
texas
lope68 Offline OP
lope68  Offline OP
texas
first I like to say hi, new to moparts. Looking for advise on what bearings to use for a 470,and which rods would you use long or short. Motor for 68 dart more street than strip.
Thank
Re: looking for advice on 470 [Re: lope68] #1803593
04/14/15 09:35 PM
04/14/15 09:35 PM
Which block are you going to use, low deck 400 or a high deck 440? It really makes a difference on the both the rod length and main bearings shruggy I've built both with the 3.90 or 3.91 stroke cranks, they rock up
Re: looking for advice on 470 [Re: Cab_Burge] #1803624
04/14/15 10:00 PM
04/14/15 10:00 PM
texas
lope68 Offline OP
lope68  Offline OP
texas
The block is a 400,and I used a 440 crank for the 470.
Lope68
Re: looking for advice on 470 [Re: lope68] #1803651
04/14/15 10:18 PM
04/14/15 10:18 PM
Welcome aboard! 400 block/440 crank/440 rods/KB 280 pistons (iirc). I'd offset grind the crank to get 470 cubes. Not sure if you need/want 360 oiling main bearings but that would be my personal choice (rods are the end of the (oiling) line & the cause of alot of oil starvation mishaps. You did say street but you know how that goes! I'd consider some stealth heads/get quench/desired SCR/appropriate cam for a spot on long block then work on ign/fuel/exh etc. Post how it goes
Re: looking for advice on 470 [Re: RapidRobert] #1804236
04/15/15 03:51 PM
04/15/15 03:51 PM
dogdays Offline
dogdays  Offline
A 470 is 4.375" 400 block with offset ground 440 crank, new stroke is 3.91, and rod journal is 2.200", bigblock chevy size.
A 6.535 chevy rod will give bore/stroke of 1.67 which is good for street but you could go even shorter on the rod to 6.385, which is bigblock chevy +0.250 length, giving R/S ratio of 1.63.
Zero deck with the 6.535" rod is 1.490 CH
Zero deck with the 6.385" rod is 1.640 CH
The 470 is quite close dimensionally to a 455 buick engine and those engines liked to rev, at least until they blew due to oiling issues. I loved my '70 GS455, it was a blast to drive. Your 470 will be even better because of stronger and lighter components.
Under no circumstances go longer than 6.535 on the rod length, not for a mostly street engine.
R.
Re: looking for advice on 470 [Re: RapidRobert] #1804311
04/15/15 05:40 PM
04/15/15 05:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thank
shruggy
Re: looking for advice on 470 [Re: lope68] #1804321
04/15/15 05:53 PM
04/15/15 05:53 PM
AndyF Offline
AndyF  Offline
The answer on which rods to use depends on several factors. First question is which rod journal does your crank have? If you have a BB Chevy rod journal then there are more options than if the crank has Mopar journals.
I'd probably use a 6.70 long BBC rod but it depends on the piston choice as well as other things. The 440Source 470 kit uses a 6.535 rod which is an okay choice also.
Re: looking for advice on 470 [Re: JohnRR] #1804324
04/15/15 05:58 PM
04/15/15 05:58 PM
[quote=RapidRobert]Welcome aboard! 400 block/440 crank/440 rods/KB 280 pistons (iirc). I'd offset grind the crank to get 470 cubes. Not sure if you need/want 360 oiling main bearings but that would be my personal choice (rods are the end of the (oiling) line & the cause of alot of oil starvation mishaps. You did say street but you know how that goes! I'd consider some stealth heads/get quench/desired SCR/appropriate cam for a spot on long block then work on ign/fuel/exh etc. Post how it goes
shruggy
So what is your problem with this John?
Re: looking for advice on 470 [Re: RapidRobert] #1804374
04/15/15 07:25 PM
04/15/15 07:25 PM
dogdays Offline
dogdays  Offline
It seems you skipped over the part where he said he was going to build a 470. Everything in your reply was aimed at a 451.
Just Checkin'
R.
