Re: looking for advice on 470
[Re: lope68]
#1803651
04/14/15 10:18 PM
04/14/15 10:18 PM
RapidRobert
Welcome aboard! 400 block/440 crank/440 rods/KB 280 pistons (iirc). I'd offset grind the crank to get 470 cubes. Not sure if you need/want 360 oiling main bearings but that would be my personal choice (rods are the end of the (oiling) line & the cause of alot of oil starvation mishaps. You did say street but you know how that goes! I'd consider some stealth heads/get quench/desired SCR/appropriate cam for a spot on long block then work on ign/fuel/exh etc. Post how it goes
[Re: RapidRobert]
#1804236
04/15/15 03:51 PM
04/15/15 03:51 PM
dogdays
A 470 is 4.375" 400 block with offset ground 440 crank, new stroke is 3.91, and rod journal is 2.200", bigblock chevy size.
A 6.535 chevy rod will give bore/stroke of 1.67 which is good for street but you could go even shorter on the rod to 6.385, which is bigblock chevy +0.250 length, giving R/S ratio of 1.63.
Zero deck with the 6.535" rod is 1.490 CH Zero deck with the 6.385" rod is 1.640 CH
The 470 is quite close dimensionally to a 455 buick engine and those engines liked to rev, at least until they blew due to oiling issues. I loved my '70 GS455, it was a blast to drive. Your 470 will be even better because of stronger and lighter components.
Under no circumstances go longer than 6.535 on the rod length, not for a mostly street engine.
R.
[Re: JohnRR]
#1804324
04/15/15 05:58 PM
04/15/15 05:58 PM
RapidRobert
[quote=RapidRobert]Welcome aboard! 400 block/440 crank/440 rods/KB 280 pistons (iirc). I'd offset grind the crank to get 470 cubes. Not sure if you need/want 360 oiling main bearings but that would be my personal choice (rods are the end of the (oiling) line & the cause of alot of oil starvation mishaps. You did say street but you know how that goes! I'd consider some stealth heads/get quench/desired SCR/appropriate cam for a spot on long block then work on ign/fuel/exh etc. Post how it goes
So what is your problem with this John?
