The Scat 9000 cast crank kit came with King bearings which I want to replace. I would like to try another bearing supplier other than King .Bearings are standard size. Rods could be clevite H series chamfered but $$?? Mains I would like to stay with 1/2 grooved and have the wide thrust shoulder for the 1974 up block { 4 spd car} {kings were not }. The cast crank has the wide radius filet.I looked at both Summit and Jegs but confusing info , therefore asking for recommendations . Thanks
