What happened to this bearing #180322
01/01/09 06:39 AM
01/01/09 06:39 AM
Finland
mopster Offline OP
mopster  Offline OP
Finland
This is main bearing from my friends engine. Something is wrong, but what? It has some brown colour and little spots in it, and in some areas the tin surface has been flaking off. Clearances are fine, .0025" rods and .003" mains.
Could too hot oil, or some kind of oil pump cavitation problem cause this? My friend doesnīt run oil temp gauge, but oil pressure has been dropping in some cases, like in highway with engine running 5000 rpms, indicating that oil is getting too hot. He does run B&M 5 x 11" oil cooler. Itīs a sbc engine with hv oilpump in it, and he has been told that the hv pump is causing a cavitation problem, and that he needs smaller volume pump with some kind of anti-cavitation grooves. Does this sound right to you?
Re: What happened to this bearing [Re: mopster] #180323
01/01/09 10:46 AM
01/01/09 10:46 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I saw something similar on a mains bearing in my old 528. Looked like the surface was de-laminating, had a sort of crazing effect to it. Happened on only one half of the bearing as well. Never figured out why, just put it down to a manufacturing fault. Didn't mark the crank either. Cant remember any disclouration though
Are all the bearings like this? in our case it was just one shell.
Re: What happened to this bearing [Re: mopster] #180324
01/01/09 10:48 AM
01/01/09 10:48 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Pump cavitation (if I can remember my fluid dynamics classes from college) usually occurs from problems on the suction side of the pump (suction tube too small, restricted, etc.) You would usually see this on the pump rotors.
What you have here might be from detonation/cap walk, although oiling could be an issue as well (brown could indicate overheating).
Oil pressure should not be dropping at 5000. If you follow the rule of thumb you need at least 50lbs at that speed. What is the pressure dropping to? A high volume pump will also provide high pressure if all of the clearances are correct.
Check and make sure there is no air leaks around the pick up hole in the pump. The pump body has been known to crack if the pick up is over tightened.
Re: What happened to this bearing [Re: torkrules] #180325
01/01/09 11:37 AM
01/01/09 11:37 AM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
with the pics you posted I would say It looks like there is/was some detnation going on!
Re: What happened to this bearing [Re: mopster] #180326
01/01/09 12:08 PM
01/01/09 12:08 PM
The Grand State of Confusion-O...
SKR8PN Offline
SKR8PN  Offline
Look at how much of the oil groove in that bearing is either filled with bearing material or worn away. Oil starvation would be my first guess. What do the rest of the bearing upper and lower shells look like??? How about the rod bearings??
Karma has no menu. You get served what you deserve.
Re: What happened to this bearing [Re: mopster] #180327
01/01/09 12:41 PM
01/01/09 12:41 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
From THAT picture ( its VERY hard to read a bearing from a picture) but I would say you have bearing fatigue or whats called surface fatigue. Ity doesnt appear to be 100% cavitation or lack of oil to me. That is what most people want to say is lack of oil, but there are many factors that go into reading bearings, and they are like spark plugs, most read them wrong.
Fatigue can be ( as mentioned) detonation, overloading, ( which can be lugging the motor, detonation and overfueling, rich condition thinning oil). It could also simply be a bad bearing choice for the application.
You would want to really take a good look at the distributor and timing, make sure the oil pick up is in good shape and sealed well, there is proper clearance pan/pickup and make sure its not overly rich.
With all that being said, it does appear that there could be some surface wiping, which would indicate some starvation, but it usually doesnt show the signs of the distressed plating ( the wrought peppering look) that your bearing is showing. Without knowing all the exact details of the bearings, clearances, how it was assembled, primed properly etc, as well as the visual first hand observation of the bearings, its educated analysis from our chairs.
Again, I still believe bearing fatigue from what I see.
My
RIP Monte Smith
Re: What happened to this bearing [Re: mopster] #180328
01/01/09 01:14 PM
01/01/09 01:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you can take a couple more pics, 1 to get the
glare off of it and take a pic of the thickness of
the bearing(side view) to see how much wear it has.
It looks like the oil groove is full of material
or it could be worn away. But looking at the end
of the bearing it would show a different material
if it was worn that thin
Re: What happened to this bearing [Re: MR_P_BODY] #180329
01/01/09 01:19 PM
01/01/09 01:19 PM
Syracuse,NY
Syracuse,NY
Yes its just hard to tell. The bearing filling up could be after the initial damage was done which may or may not be the reral problem, only a result of. Just so hard to tell from pics.
RIP Monte Smith
Re: What happened to this bearing [Re: CompWedgeEngines] #180330
01/01/09 01:30 PM
01/01/09 01:30 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
The way the groove seems to taper I would have to belive that is not a full groove bearing.
JAKES AUTOMOTIVE
Re: What happened to this bearing [Re: JAKE68] #180331
01/01/09 02:41 PM
01/01/09 02:41 PM
Finland
mopster Offline OP
mopster  Offline OP
Finland
The groove isnīt filled, itīs a 3/4 groove bearing, and theres really nothing wrong with the groove. No surface wiping either, only the thin tin layer has been flaking. So I donīt think itīs oil starvation. Detonation shoudnīt be a problem either, itīs a quench motor with 8.1 dynamic CR.
We thought the problem is oil temp related because this engine has been ruining the oil very fast. After about 600 street miles the oil looks really bad and it has lost most of its viscosity. Oil used is valvoline VR1 20W/50. Oil pressure drops to 55 psi from normal 65 psi when driving in highway at 5000 rpms for about 10-20 miles, so the oil is probably running very hot.
Theory about the HV oil pump is, if I have unerstood it right, that itīs producing more oil at higher rpms that the engine can take and basicly cooking up the oil. Cavitation probably isnīt the right term. Pressure relief valve is circulating the oil back to suction side, so it most likely just creates more heat as the oil is circulating very fast around the pump.
Re: What happened to this bearing [Re: mopster] #180332
01/01/09 02:49 PM
01/01/09 02:49 PM
Finland
mopster Offline OP
mopster  Offline OP
Finland
Another pic.
Re: What happened to this bearing [Re: mopster] #180333
01/01/09 02:50 PM
01/01/09 02:50 PM
Finland
mopster Offline OP
mopster  Offline OP
Finland
One more.
Re: What happened to this bearing [Re: mopster] #180334
01/01/09 03:03 PM
01/01/09 03:03 PM
Cab_Burge Online work
Cab_Burge  Online Work
One more.
That bearing looks like it has been real hot I'm suprised that it didn't spin or fold up and sieze on the crankshaft. 20 minutes at 5000 rpm on the hiway
Re: What happened to this bearing [Re: mopster] #180335
01/01/09 03:33 PM
01/01/09 03:33 PM
can you post a picture of the mating shell. my guess is it doesn't look as bad as the one you already posted. if that's the case, detonation, overloading would be the likely culprits.
Re: What happened to this bearing [Re: mopster] #180336
01/01/09 03:44 PM
01/01/09 03:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
THe person with the cooking oil theory probably has worked with hydraulics, any time your pushing oil over a relief valve it creates some heat, but a 60 PSI relief likely wouldn't create much...At 3000 psi you don't want to push allot of oil past the relief so you need to be able to size the pump to the flow...60 PSI not so much...
BTW This is what cavitation at 3000+ psi does...Air bubbles actually explode & that energy erodes metal...
Re: What happened to this bearing [Re: mopster] #180337
01/01/09 04:04 PM
01/01/09 04:04 PM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
With the detonation, you are right 8.1 should not cause detonation, but other factors could cause even and 8.1 motor to detonate (something glowing hot in the combustion chamber, bad fuel, timing, lack of mixture swirl, a combination of the above, etc.) I guess you would need to look at all the evidence to rule this out (pistons, plugs, rod bearing, etc)
As far as the pump, others can correct me if I am wrong, but my understanding is that Mopars have a very efficient pressure relief system where the oil does not get dumped directly to the sump (I believe Chebby does this). On Mopars, as you said, the oil swirls around the rotors which taxes the suction side less which in turn results in cooler oil (like I said, I could be wrong on this as I'm going by memory).
Re: What happened to this bearing [Re: torkrules] #180338
01/01/09 04:53 PM
01/01/09 04:53 PM
while your at it, how about a picture of the back of the bearing shells? (both)
Re: What happened to this bearing [Re: torkrules] #180339
01/01/09 05:02 PM
01/01/09 05:02 PM
Finland
mopster Offline OP
mopster  Offline OP
Finland
This is a sb chebby engine we are talking about. Sorry for posting here, but I donīt hang out in chebby forums, and I also didnīt thought that we need a chevy guy to read a bearing
Back to the issue. Rod bearings were looking better, only a little brown colour and spots, but no flaking. Mains were all looking like the one in the pic. If it was a detonation issue, shoudnīt the rod bearings be worse.
To me it looks like the bearings have just been running too hot, and the tin surface has been baked. And if so, we should figure out why. The guy who was thinking that HV oil pump is cooking the oil is actually a race parts dealer, and he claims that a pump with anti-cavitation grooves and only 10% more volume (instead od of 25%) will cure the problem.
Re: What happened to this bearing #180340
01/01/09 05:14 PM
01/01/09 05:14 PM
Finland
mopster Offline OP
mopster  Offline OP
Finland
Sorry, no picture of the other halve, but I think it looked the same. Iīll ask my friend.
Re: What happened to this bearing [Re: mopster] #180341
01/01/09 05:15 PM
01/01/09 05:15 PM
please post good clear pictures of the front and back of a pair of rod bearings and main bearings.
it's hard to tell what the problem is when it's only being described by someone. pictures ar worth 1000 words.
