Classic Auto Air with 6pack...any concerns? #180303
01/01/09 03:41 AM
01/01/09 03:41 AM
Heart of Ohio
4boxers4 Offline OP
4boxers4  Offline OP
Heart of Ohio
Thinking of adding the Classic Air setup to my 440 RoadRunner. Anyone had any concerns with the fit? I also have stealth heads. Thanks...
Persistance is omnipotent Durability Engineer, Chair and Couch division...
Re: Classic Auto Air with 6pack...any concerns? [Re: 4boxers4] #180304
01/01/09 05:10 AM
01/01/09 05:10 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
There are a number of kits to mount Sanden compressors that will work, if you want the compressor less obvious it can be mounted below the alternator, or most kits mount on top of the engine...Personally I would hide the compressor sp the Sixpack remains the focal point the only thing is to do this you need to run a electric fuel pump...There are a few kits shown at the link below
http://www.bouchillonperformance.com/BPEACmountingbrackets.asp
Re: Classic Auto Air with 6pack...any concerns? [Re: 1_WILD_RT] #180305
01/01/09 11:32 AM
01/01/09 11:32 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
what a sweet setup that low mount compressor bracket is!! that would be 160 bucks well spent
Re: Classic Auto Air with 6pack...any concerns? [Re: 1_WILD_RT] #180306
01/02/09 05:38 PM
01/02/09 05:38 PM
Heart of Ohio
4boxers4 Offline OP
4boxers4  Offline OP
Heart of Ohio
Just the option I was looking for. Thanks RT!
Re: Classic Auto Air with 6pack...any concerns? [Re: 4boxers4] #180307
01/02/09 11:27 PM
01/02/09 11:27 PM
Bucks County, PA
500Stroker Offline
500Stroker  Offline
Bucks County, PA
Here's pix of the Classic air mounting
Re: Classic Auto Air with 6pack...any concerns? [Re: 500Stroker] #180308
01/03/09 01:24 PM
01/03/09 01:24 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Give USCartool "John" a call he is a classic autio air dealer and installer
Re: Classic Auto Air with 6pack...any concerns? [Re: 340SIX] #180309
01/03/09 09:09 PM
01/03/09 09:09 PM
Shoreline, Washington
72roadrunnergtx Offline
Here is one of Bouchillon Performance compressor mounting set-ups. Neatly fits under the six-pac/Air Grabber air cleaner.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Classic Auto Air with 6pack...any concerns? [Re: 72roadrunnergtx] #180310
01/11/09 01:17 PM
01/11/09 01:17 PM
Heart of Ohio
4boxers4 Offline OP
4boxers4  Offline OP
Heart of Ohio
Thanks guys! That was another question in my mind was the interference for the air cleaner. I am thinking of using a polished compressor but the natural finish looks better than I thought it would have.
Re: Classic Auto Air with 6pack...any concerns? [Re: 4boxers4] #180311
01/11/09 01:20 PM
01/11/09 01:20 PM
Heart of Ohio
4boxers4 Offline OP
4boxers4  Offline OP
Heart of Ohio
Are you guys happy with the performance of the cooling of the system? How about Horsepower loss? Anything noted too obvious or just a mild drop as expected? Thanks again!
Re: Classic Auto Air with 6pack...any concerns? [Re: 4boxers4] #180312
01/11/09 02:19 PM
01/11/09 02:19 PM
Performance of the A/C system? Have yet to put it to the test on a really hot day however the air blowing out of my vents now is as cold if not colder than any of my contemporary daily drivers.
Horsepower drop? Barely perceivable for me, I had expected to have to add another idle solenoid wired to function with the compressor cycling. At idle there may be 40rpm or less drop in idle speed when compressor is operating. Other than the cold air in my face I don’t even notice A/C is on while driving.
Here’s some more shots of air cleaner to compressor clearance.
Re: Classic Auto Air with 6pack...any concerns? [Re: 4boxers4] #180313
01/11/09 02:34 PM
01/11/09 02:34 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Bouchlin performance stuff here. Have it on both of my cars with stock AC box inside and they both work great. Even my black car stays cool easy usally on low. As far as horse power loss, there is a little but it's hot as heck outside too, so some of it is the weather. Well worth the cost.
Re: Classic Auto Air with 6pack...any concerns? [Re: Challenger 1] #180314
01/11/09 05:53 PM
01/11/09 05:53 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Good info. Don't wan't to hijack but does anyone have a pic of the 'low mount' set up?
Re: Classic Auto Air with 6pack...any concerns? [Re: Classof70Chally] #180315
01/11/09 07:21 PM
01/11/09 07:21 PM
Re: Classic Auto Air with 6pack...any concerns? [Re: 72roadrunnergtx] #180316
01/13/09 12:09 AM
01/13/09 12:09 AM
Heart of Ohio
4boxers4 Offline OP
4boxers4  Offline OP
Heart of Ohio
Awesome pics! Yes the info you have included really helps me feel good about my investment. I DO like Bouchillion s low driver side mount too. Thanks guys! You have been VERY helpful.
Re: Classic Auto Air with 6pack...any concerns? [Re: 4boxers4] #180317
01/13/09 08:31 PM
01/13/09 08:31 PM
Here is some info for all of those that are interested in putting A/C in your old muscle car.
Some background on MY knowledge on the subject. For 11 years I worked for a muli-divisional company that among other things had been involved in the aftermarket automotive air conditoning business since 1957. I learned that there is no real magic in putting togather a custom system other than knowing where to buy the componant parts required. Most of the things you need are universal to nearly all cars such ad the condenser and dryer which is subject to the available space in front of your radiator, (the bigger the better) the refrigeration lines, and the compressor which the necessary model is dictated by the space available and which side the lines attach. These parts are readily available at parts stores or from suppliers of aftermarket A/C installers/suppliers.
The evaporator and the air vents are really the only things that present a problem for most people as they seldom know what they need or where to place them. The typical set up that most people want is something that is as hidden as possible or as close to factory looking as they can get.
For Mopar B bodies this varies only slightly from 1962-1975 or so. In nearly all of these applications you are going to want an under dash evaporator mounted on the passenger side under dash. This is the same basic location of a factory A/C evaporator. These are available as A/C only or as a Heater/A/C unit which would replace your existing factory heater unit. These evaporators were available in several different configuation especially with differences in the distribution outlets that the vent hoses attached to. Typically, a B body can use an evaporator that has all dischages on the top or two on top and one each on the sides. You then simply route the flexible hosing to the discharge vent openings.
On 62-67 the best looking set up wound be the simple slim line under dash vents that can be screwed to the long flat lower dash edge. One driver's side, one pasenger side and two in the middle. This also resembles the original factory A/C to some degree.
One 68-70 the dummy plates that cover the openings for factory A/C ducts on the ends of the dash both passenger and drivers side can be removed and aftermarket vents can be used here as the dash is already set up for this purpose. Two other vents can be place under the dash in the middle for additional air distribution.
71-up I am not real familiar with as I seldom pay much attention to these cars but you get the idea.
The controls are available in a compact panel that can be placed under the dash or IN your dash as space permits if you are willing to cut holes for this. There are several control panels available that can be used in placed of your factory controls.
So, where do you get these evaporators, vents and controls? Frig-King was the oldest manufacturer of these systems and custom parts. This is the company that my old company used to use. We install these sytems in off road equipment (Catapiller etc.) limos, flower vans, etc., etc. most anything you can think of. They offered a big selection of evaporators, and vents. I could not find them online and it has been nearly 20 years since I used them. I suspect someon has absorbed them or they are simply out of business, but I did see several places that sell Frig-King parts so you may have some luck there. The two links I list below show the componant parts I refer to above. Both offer complete kits or seperately sold parts. The first link has nice pictures of the evaporators, and a better selection of controls. The second link has prices on their site.
With this info you can piece togather your own complete system and buy the componants as you go if you so desire.
Hope this helps in your quest to be COOL.
http://www.hotrodair.com/index.cfm?ptype=results&Category_ID=2&home_id=2&mode=cat
http://www.nostalgicairparts.com/ac/duct-hose-and-vents-4.php
Re: Classic Auto Air with 6pack...any concerns? [Re: Challenger 1] #180318
01/13/09 09:18 PM
01/13/09 09:18 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Same here.
Re: Classic Auto Air with 6pack...any concerns? [Re: 4boxers4] #180319
01/15/09 12:44 PM
01/15/09 12:44 PM
i used classic air on my 69 rr that came with factory air. it is very easy to adapt it to the factory air dash vents instead of using the cheesy plastic vents that come in the kit.
