Car stops in 2nd gear
#1802508
04/13/15 05:21 PM
04/13/15 05:21 PM
Posts: 678 Marshall TX
Texas383
Marshall TX
I drove my '69 Super Bee to the local cruise night last night. It did something it has never done in the 30+ years I've owned it. When manually shifting into 2nd gear from 1st the car immediately stops as if I slammed on the brakes. There is not any raking sound or anything like that in the trans. I have to manually put it back in 1st to move again. If I put it in Drive it shifts 1-3 great. What has happened?!?!
1969 Y2 Super Bee 1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
Re: Car stops in 2nd gear
[Re: Texas383]
#1802526
04/13/15 05:58 PM
04/13/15 05:58 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The rear band failed to release on the manual 1-2 upshift. If it only did it once and was OK thereafter, the servo piston probably cocked in it's bore.
[Re: Texas383]
#1803165
04/14/15 12:50 PM
04/14/15 12:50 PM
Texas383
Marshall TX
It wouldn't do it every time I shifted manually but most of the time. I've shifted manually for many years and it's habit so I would do it even when I wasn't intending too.
What's the fix?
I always thought STOP stood for Slow To Obvious Pause
[Re: Texas383]
#1803312
04/14/15 03:24 PM
04/14/15 03:24 PM
John_Kunkel
Rio Linda, CA
There are mods to the rear servo piston that help prevent cocking but the best solution is to install a billet rear servo kit...available from many sources including the Swap Meet section here.
[Re: Texas383]
#1804354
04/15/15 06:37 PM
04/15/15 06:37 PM
Texas383
Marshall TX
Will it hurt to drive it using "Drive" and no shifting manually?
